Links
Old 04-18-2008, 09:10 AM   #1 (permalink)
Question Brake pads
I think I am in need of new brake pads. They are making alot of dust and making a slight squeal. I had the Disco checked out buy a local mechanic who is a friend of mine. He said the brake pads look new on it. They are really thick. However, the three amigos have been coming on. If I turn the truck off and restart it, the lights go off. I have been trying to keep the brakes sprayed out. This seems to help until the dust has time to build up again. It seems the previous owner has put cheap pads on it. Will replacing the pads with quality pads prevent the lights from returning? Thought they would stay on if it was something that a dealer would have to reset. The lights are off now (don't know how long this will last). Also, is it a good idea to have the rotors turned while doing this? Thanks for any help.
Neo1975 is offline   Reply With Quote
Old 04-18-2008, 10:27 AM   #2 (permalink)
What brand of pad is on your truck?
You may be able to correct this issue if you remove the pads and apply lots of sound deaden material in the backing plates before reinstalling them, or go to a better pad.
Old 04-18-2008, 10:43 AM   #3 (permalink)
'00 DII Member
auwesman's Avatar
+1 on removing and applying brake squeel. Sometimes the vibration from squeeling will set off the 3 amigos so it may not neccisarrily be the brake dust.
How many miles are on your rotors? From my understanding it isn't recommended to turn the factory rotors, but someone may want to correct me on this.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 04-18-2008, 01:23 PM   #4 (permalink)
Not sure what brand the pads are. The rotors have alittle over 117,000 miles on them.
Old 04-18-2008, 01:47 PM   #5 (permalink)
If in fact they have that many miles on the rotors, they have to be under factory specs and are probably running pretty hot.
You may need to just start fresh, pads and rotors along with a good brake flush.
Old 04-19-2008, 10:16 AM   #6 (permalink)
I am checking prices on rotors and pads. I will also do some searching on here to see what people are using. I may also replace the brake hoses with braided stainless lines while I am at it.
Old 04-19-2008, 10:43 AM   #7 (permalink)
'00 DII Member
auwesman's Avatar
While you are price shopping, give Tony a call (He owns Cerrones in California). He had the best price I could find on Akebonos I could find.
Tony at Cerrone's European
1-800-736-7992
'00 DII
'07 Toyota Taco
War Eagle!
Old 04-19-2008, 06:34 PM   #8 (permalink)
I guess I can call Tony on Monday. Has anybody done any business with Brake Planet? They have some rotors at a good price. The warranty sounds good also. I wonder if their rotors are good, and if they stand behind their warranty.
99-03 LAND ROVER DISCOVERY Series II - 2 Front Silver Slotted Drilled Brake Rotors: NL031046 BrakePlanet
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Where can I get... johnnybob06 Discovery Series II 7 02-21-2007 01:44 PM
Brake pads me.guevara Discovery Series I 13 05-01-2006 11:48 AM
Brake Rotors and Pads How-To werldcup Discovery Series II 4 03-23-2006 07:16 PM
What should I have done during maintenance? appstatedisco Discovery Series I 2 09-12-2005 07:57 PM
