Old 05-12-2008, 08:12 AM   #1 (permalink)
Default Brake Pedal vibrating
I have a 97 Discovery and it seems when the road is bumpy the brake pedal will vibrate and the ABS seems to fail, wondering if there is a relay or ABS module that may be defective. Have to press harder on pedao when this happens. Any help will be appreciated.
Thanks Walter
onguard is offline   Reply With Quote
Old 05-12-2008, 12:50 PM   #2 (permalink)
If you aqre looking for a reply, you might post this in the Disco 1 section.
Is your ABS light on?
Old 05-12-2008, 03:41 PM   #3 (permalink)
its on occasionally intermittent
Hard Brake Pedal Kevin88RRC Range Rover Classic 5 04-17-2008 03:10 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Brake Pedal...weird vibrations when pushed boxer Range Rover Classic 1 12-29-2006 04:45 AM
Long Brake Pedal Syndrome? PCrover Discovery Series II 21 06-29-2005 10:12 AM
Hard brake pedal.. Serg Range Rover Classic 3 03-27-2005 09:03 PM
