Brake, TC, ABS, HDC lights on after lift install.
I have a 2000 Land Rover Discovery with 153,000 miles. I havent had any problems with it lately. I installed TF's 3in lift on Sunday and when I turned on my car I had the Brake, TC, HDC and ABS lights on. Everything is working normally, but it freaks me out to drive with a christmas tree in the dash warning center. I did unhook my brakes and ABS lines to do the install, but I hooked everything back up. I even double checked after i saw the lights on. Any ideas? Is there any place I can pick up an ABS code reader on the cheap? Has anyone else experienced this problem? Another good thing to note is that I already did the ABS shutter valve workaround about 7,000 miles ago. And I double checked the connections there and all seems to be good. So, I would appreciate any ideas.I saw one other thread on here about all four lights being on after a pressure wash, but all other threads I have read are only the 3 amigos, and most of them are the shutter valve. But I am willing to check and recheck anything you guys think it could be.
