Old 06-28-2007, 08:19 AM   #1 (permalink)
Polish and proud of it.
TsiArt's Avatar
Default Can't shift into the Low range
Hi,
I have this problem with my new 2000 LR Disco II .
I can't shift the xferr case out of the high gear . It will not go into neutral of the low gear . The leaver moves close to the 'N' in you push it .
Now would that be the problem with the fork in the xferr case or the linkage it self ?
Now I did it in my other LR b4 and it was tugh to move it , but it did . In this one it's just stuk .
What should I look at ?
Now I found couple of posts but nothing that would explain the same problem i have .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 06-28-2007, 09:03 AM   #2 (permalink)
'00 DII Member
auwesman's Avatar
Here is a very helpful thread.
http://www.lrrforums.com/showthread.php?t=422
Are you trying to shift while rolling at about 5 mph, or doing it while standing still?
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 06-28-2007, 09:04 AM   #3 (permalink)
KevinNY's Avatar
Linkage is probably frozen up from never have been moved.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is online now   Reply With Quote
Old 06-28-2007, 11:23 AM   #4 (permalink)
TsiArt's Avatar
Most likely it is.
The first owner was rental place in FL for the first 30k . and the second owner had it for 100k and i don't think he toke it off- road as far as durt road.
Now I never paid attention to the linkage , but is it a cable of levers and shit?
Old 06-28-2007, 01:06 PM   #5 (permalink)
rmuller's Avatar
linkage is a metal rod that goes into the transfer case... if you can, pop the cover off of the top, and spray some penetrating lubricant (pb blaster, wd40) into it... when you're trying to engage it, try to have a little bit of speed (3-5mph) , it makes it easier to pop it in.. so just throw it in neutral, let it roll a bit and push into it.
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
Old 09-18-2007, 04:39 AM   #6 (permalink)
TsiArt's Avatar
So I pulled my front driveshaft out ( xferr case baring is bad ). And i figured wille I'm there I'll look it over .
I can see the cable move in and out but it looks to me like a leaver? in the xferr case is barly moving . I will need to take a picture or video of it .
