» Sponsors
» Sponsors
Old 06-29-2009, 09:26 AM   #1 (permalink)
Default Cargo door broken
Hey guys. I've got an '03 Disco II. It started getting a little sticky on the cargo door handle, and then one day it got stuck. I was able to pry it back, but now I can't get the door open, and it won't open from the inside either. Any help anybody?
Jmarchell1211 is offline   Reply With Quote
Old 06-29-2009, 11:54 AM   #2 (permalink)
Super Moderator
When was the last time you cleaned and lubed the latch a lever assembly?
Old 07-03-2009, 01:42 AM   #3 (permalink)
I'm having almost the same issue however I can manually unlock it from inside by pulling the handle otherwise, I can't get it unlocked. The actuator in the door clicks when I hit the lock/unlock button but the door remains locked. I don't mean to sound ignorant about the issue, im still new to the Land Rover world.
2002 Land Rover Disco II
RoverX1325 is offline   Reply With Quote
Old 07-03-2009, 07:55 AM   #4 (permalink)
Don't follow me, You won't make it!
Chack out my post on Benji's rear door latch/handle thread. Maybe it will help.
Shane R Carnes is offline   Reply With Quote
Old 07-04-2009, 11:03 AM   #5 (permalink)
Default lube
i had this problem about a month ago, I would have to pry the handle back into the close position. so get out your fav rust inhibator and give it a good shot, let it soak for a while and repeat if nessary.
hope it works.
discomat is offline   Reply With Quote
02 SE Rear Cargo Bins brian4d Discovery Series II 22 04-16-2009 04:42 PM
Discovery II Cargo Area Dimensions NOT area Tekbench Discovery Series II 3 03-15-2009 08:45 PM
Genuine OEM Land Rover LR3 Steel Cargo Barrier harleyabbablue Land Rover Parts and Accessories 0 07-26-2008 01:59 PM
alternative to cargo drawers hermanpj Range Rover Classic 17 04-17-2008 08:52 PM
Do Disco 1 LSE7 have larger cargo room than a SE SafariDave Discovery Series I 2 03-26-2008 06:49 AM
