Old 05-08-2007, 08:40 PM   #1 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
Default CB whip antenna recommendation?
ok I know I've asked about CB's before but still need more advice.
1) has anyone mounted a Whip to the spare tire mount?
2) if you have what brand/model did you use for the whip
3) what brand/model mount did you use.
and lastly
4)where precisely did you place the mount?
thanks guys.
Rudy
RudemanRB is offline   Reply With Quote
Old 05-09-2007, 04:58 AM   #2 (permalink)
bama's Avatar
good questions, i also would like cb reccomendations.
also in the interior where did yall mount your cb unit?
pics are always helpful
Robbie
Acworth Ga--thats Northwest of Atlanta (ATL MOFO)
"The more people I meet the more I like my dogs"
"the garage"
2002 Discovery(my baby
2" OME LIFT
265/75/16 Mickey Thompson mtz's
discovery pushbar
2005 Nissan Sentra 1.8s
bama is offline   Reply With Quote
Old 05-09-2007, 06:52 AM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
If you mount the antenna on the tyre mount, it will be directional. That is it will pick up signals from the rear a lot better than from the front. You will also have issues with wiring it.
Firstly you need a antenna that does not require a ground plane.
The best spot to mount it is in the centre of the roof. Mount it on one of your roof bars or put a bar between your roof bars and mount it on that. Run the cable inside through your door seal. Better still, just drill a hole in your roof and mount the antenna directly to the roof.
Old 05-09-2007, 06:53 AM   #4 (permalink)
Thor's Avatar
36" firestick on the upper mount on ARB bumper worked very well.
Underhood mount (thin mount passes through the gap between the hood and the quarter panel) then holds the antenna above the quarter panel.
Whip antennas like to hit people, your car, other cars, etc.
Have it tuned.
Todd
Carpe Rangius Roverum
Old 05-09-2007, 07:25 AM   #5 (permalink)
Rudy,
Another option would be to use a base mounted Wilson 1000 antenna with treir 5 foot antenna. When mounted to the center of your Discos steel roof it gives you a perfect 360 degree signal strength. The antenna is designed to be removed if you want and while on the trail, if you are in heavy trees, you just knock a few leaves off as you go.
From what I found in talking to a few CB shops 4 years ago, this would give me by far the best signal transmitting and reception.
Old 05-09-2007, 05:55 PM   #6 (permalink)
HMBRover's Avatar
I use a 4 foot top loaded fiberglass antenna on the spare tire mount and it works fine. The antenna is similar to a Firestick but cheaper (got it at Fry's Electronics, Sunnyvale CA). The key is to have the top foot of the antenna ABOVE the roof of the truck since most radiation on a top loaded whip is from the top. I think the Firestick antennas are good ones but you pay a bit more for the name.
The mount attaches to the upper right bolt which holds the spare tire bracket onto the door (Disco II). To attach the mount, you have to remove the rear door panel since these bolts have a free spinning nut on the inside. You will want to do this anyway to route the coax through the washer tube grommet to the outside.
The antenna mount I made myself out of about 1.5 inches of bed frame angle iron. This material is tough steel angle about 1.75" x 1.75". Cut, drilled and ground into shape, it works perfectly. A couple coats of Rustoleum will keep it from rusting. Be sure to mask the antenna mount hole (1/2") and the mounting hole so the whole thing is grounded to the rear door.
I haven't investigated the resulting antenna pattern but it is likely skewed compared to a roof mounted antenna. The important thing is to tune the antenna for minimum SWR for the channels you normally use after installation. You can purchase an SWR bridge/meter at your local truck stop for not too much. The Firestick antennas include a tuning stub for this purpose.
HTH
Brian
2004 Discovery II G4 Edition
2002 Freelander SE - Gone!
Formerly HMBFreelander
HMBRover is offline   Reply With Quote
Old 05-10-2007, 12:00 AM   #7 (permalink)
I know this is going to sound stupid, but.. what is a CB whip antenna??
Sorry!.. Just curious!
Thanks!
John-Robert
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 05-10-2007, 04:39 AM   #8 (permalink)
That just refers to the longer, usually stainless antennas in the 4 to 6 foot range.
Old 05-10-2007, 07:41 AM   #9 (permalink)
But whats the point of having a super long antenna? For the radio??
2003 Land Rover SE7
- SLS
- ACE
Old 05-10-2007, 08:05 AM   #10 (permalink)
Lenght is not the all important factor for radio reception, why does your not pick up well?
Old 05-10-2007, 02:40 PM   #11 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
For a CB radio not a radio for listening to music.
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 05-11-2007, 12:47 PM   #12 (permalink)
Mike- No, my radio works fine, I just didn't make the connection that the "CB Antenna" was for the "CB radio".. haha
And, yes. I get it now.. thanks! haha
John-Robert
2003 Land Rover SE7
- SLS
- ACE
