Old 08-03-2007, 08:06 PM   #1 (permalink)
Default Cd Changer Installation
I'm looking to put in a used Factory CD Changer into a 2001 Disco. I know the harness should be under the passenger seat. I'm wondering where though. I've looked and there seems to be a lot of wiring for the power seats. Has anyone had experience installing one?? Could it be tucked in under the carpet??
A
ashrx is offline   Reply With Quote
Old 08-04-2007, 05:10 AM   #2 (permalink)
Yes, it could be tucked under the seat or carpet. Lookk for a wire harness that has a matching plug to what is on your CD player.
Old 08-10-2007, 04:00 PM   #3 (permalink)
Is the cable usually installed even tho the cd was not? I have not been able to find the cable either.
Thanks
avsfans33 is offline   Reply With Quote
Old 08-10-2007, 04:15 PM   #4 (permalink)
On most model usually. That being said, I don't know if there were some years that maybe they weren't installed on th SD's.
Old 08-10-2007, 08:42 PM   #5 (permalink)
Default from the Discovery Owners Club
"Is my DSII pre-wired for the Land Rover CD Changer? It depends. All early US-spec leather DSIIs are pre-wired for the CD Changer. Cloth DSIIs are not. All but the first Duragrain (SD) DSIIs are not. The LE is not. For those that are not pre-wired, some additional labor is required, and you MAY need to purchase the CD Changer Brackets. The part #'s you need are as follows. You can get these from your Land Rover Parts Department:
CD Changer Data Cable P/N: LRN50520 $12.50
CD Changer Brackets P/N: LRN50530 $29.03
With thanks to Justin Dermody Last updated: Thu 17 Oct 2002, 01:50 IST."
I found this on the Discovery Owners Club. Not sure how accurate it is.
A
Old 08-15-2007, 06:06 PM   #6 (permalink)
Update: Apparently some 2001 SDs have the Cd button on the radio and Pre-installed brackets, but no data cable for the Cd Changer. Bizarre??? Yes. I installed the Cd changer, snaked the cable through the dash and under the carpet and everything is working fine.
