CDL dash light - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-17-2012, 02:09 AM   #1 (permalink)
wjsj69
wjsj69's Avatar
Default CDL dash light
Hi all,
I wanted to bring this issue up b/c there isn't much discussion about it and it could leave you stranded if you don't know what to do.
I was out running some light trails and noticed my CDL light was coming on when it was unlocked. I pulled over and noticed it was only turning on when I hit the brakes. So, I figured I would trouble shoot later and tried to pull away, but the parking safety solenoid would not let me out of park! You can see how this could be a big problem if you don't know that you can lift up the gear indicator panel and push the solenoid button in, to get into gear.
So, thanks to my knowledge of that solenoid (from installing CDL linkage B4), I made it home and found that I had a brake light out and a blown brake-light fuse. I disconnected the offending tail light, r&r the fuse, and viola! ..no more problem. Next I'll replace the bad bulb (1156), and re-install the tail light.
And now for my question; Is this a Rover safety deal, to immobilise the truck for one bad break-light? Or just a coincidence??
wjsj69 is offline   Reply With Quote
Old 11-18-2012, 06:48 AM   #2 (permalink)
Administrator
No, this is not a rover saftey feature. I would get iytoff road again and continue to lock and unlock it just in cased the CDL switch is sticking.
Let us know what you find,
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 11-18-2012, 03:29 PM   #3 (permalink)
wjsj69
wjsj69's Avatar
A-Ha! I pulled out an 1156 bulb, but it calls for a 7506 bulb! Installed and tested: A-OK. I don't know what the difference is, but I've heard of tail lights doing strange things! And now I've seen it for myself...
Hard brake and Brake light on dash with Anti lock light? DJKilmer Range Rover Classic 4 10-03-2011 09:47 PM
No CDL light??? Soggy Bottoms Discovery Series II 17 04-28-2011 06:15 AM
CDL disengage wont remove lights on dash fourstrokin650 Discovery Series II 3 09-04-2010 09:17 AM
What does this dash light mean? SeattleRRC Range Rover Classic 4 09-30-2009 06:29 PM
cdl dash light drum655 Discovery Series II 3 02-13-2006 05:53 PM
SEO by vBSEO 3.3.2
