Old 03-27-2008, 11:45 AM   #1 (permalink)
GermanlookT3's Avatar
Default CDL Lever from a 04 put on a 00....
I was reading some info on the CDL on the 99-01 Discos... They have the Lever but it doesnt go into the Truck... So someone said that you can just buy a lever from the 04 and Install it into the 99-01 and you have a CDL.
Has anybody read this? I would love to do this to my truck but Im not sure if its ok? What have you guys heard?
Disco Madness at its best
GermanlookT3 is offline   Reply With Quote
Old 03-27-2008, 11:47 AM   #2 (permalink)
KDamericano's Avatar
Just did it a few months back on my 00. Works great!
KDamericano is offline   Reply With Quote
Old 03-27-2008, 12:04 PM   #3 (permalink)
Sweet! Did you use the 04 linkage kit? I found one here with the Install Photos on the bottom of the Page.... https://www.expeditionexchange.com/kit/
Old 03-27-2008, 12:11 PM   #4 (permalink)
Have you confirmed that your t/case has the CDL??
Old 03-27-2008, 02:33 PM   #5 (permalink)
I didn't see any installation instructions, but yea that's what I used. I got it from a junkyard for $150. Last time I was at the dealer, I asked about that mechanism, and they said it was about $450, so I'm not sure where they get $700. Do a search on here or on discoweb.org for CDL and you'll find all the info you need
Old 03-27-2008, 04:55 PM   #6 (permalink)
Yeah my Disco is a 00 it has a CDL Lever.... Wow yeah 450 compared to 700 is definately a Price Jump! Im def getting one from the Dealer.
Old 03-27-2008, 05:13 PM   #7 (permalink)
PeteRice's Avatar
$450?!?! I made one for like $20...and its as tough as anything out there I'd bet.
If you are gunna get your hands dirty putting it in..all you need is a hack saw, a round file, a drill and a rivet gun and probably a few other little things...which you'll need most of those anyway, and you can make your own. Just get some steel and rods and use your imagination...it'll be sweet I swear.
Or just buy a 10mm wrench and leave it in the truck...is 30 seconds of convenience realy worth $450? I think you should be setting the CDL before you get into serious offroading, so you'll never have to lay in mud to put it on.
Just my thoughts tho.
2000 Land Rover Disco II
My Disco's a bush truck. Wtf to I care about scratches?
PeteRice is offline   Reply With Quote
Old 03-27-2008, 08:29 PM   #8 (permalink)
To be able to engage/disengage at will from the comfort of the cockpit is worth it to me, but I only paid $150 for mine. I've used it a few times here in the city during some snow storms where the side streets were covered in deep snow, but the mainstreets had been plowed down to the pavement. It was certainly nice to activate the lock through the deep stuff and then shut it off on the pavement.
Old 03-28-2008, 10:48 AM   #9 (permalink)
slangel's Avatar
You can do it using stuff for a DI - much cheaper
I think Cvc's goal is to make me vomit daily with his disgusting avatars.
slangel is offline   Reply With Quote
Old 03-28-2008, 12:37 PM   #10 (permalink)
Big mistake buying from the dealer when you can go on line to,
Roverlandparts.com and buy the old style, D1, for $150 and an 04 style, when they have them for under $400.
Old 03-28-2008, 08:45 PM   #11 (permalink)
Im not to keen on doing some cheap rod thing. I want it to look as clean and stock as possible. Not that I dont think paying $20 is awesome.. I just like to keep my Truck Clean....
Yeah Ive been searching online and I can get one for pretty cheap... I bet around 200...
Old 03-29-2008, 06:14 AM   #12 (permalink)
'99 Disco II
wimp's Avatar
I went to Roverland
It was $299 I think.
It was WELL worth the money to have a factory part that works PERFECTLY.
The D1 parts new are approx $135 if you can source all the parts. You can do it used, but it is a pain in the butt. Once it is installed, It doesn't work half as well as the 04 mechanism. It still works though!
Anyway, all the above mentioned techniques work well except for the guy who said to crawl under the truck and do it manually. You will end up not switching it when you need it most. The exhaust is very hot as well. Pain in the butt to do!
good luck!
'99 Disco II
ACE / 2" OME lift
245 75 R16 Greatyear MT/R's
wimp is offline   Reply With Quote
help!! cannot move lever.... peterbat Range Rover Classic 3 12-24-2007 12:21 PM
Gear Shift Lever Help! 2rovers Series Land Rovers 8 10-20-2006 10:44 AM
Land Rover Frequently Asked Dumb Questions (very long...but funny) JungleRR General Land Rover Discussion 0 05-26-2006 09:37 AM
shift lever boots me.guevara Accessories 2 12-22-2005 09:37 PM
Transfer lever will not move... Nantucket LR Disco Discovery Series I 3 12-13-2005 06:48 PM
