Champion RN11YCC - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 05-16-2010, 06:11 AM   #1 (permalink)
Toowild78's Avatar
Default Champion RN11YCC
I can't find any information about this plug, but it's the part number out of my hand book. I can get the following 3 plugs at NAPA what is the best path to take?
RC12YC~Cooper Plus
3071~Single Platinum
RC11PYPB4~Double Platinum.
Thanks in advance.
Toowild78 is offline   Reply With Quote
Old 05-16-2010, 06:50 AM   #2 (permalink)
Administrator
Either the Champion double platinum or the Bosh Platinum Plus 4, 4418.
By the way, how many miles on the engine, will you be throwing a set of 8 mm wires on?
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 05-16-2010, 07:49 AM   #3 (permalink)
Champion number 318, cheap, easy to find and work well in DIIs.
P. T. Schram Rover Repair
Full-service independent Land Rover facility
I ain't got much a nothing at all, but I damned sure got it made. If you don't like the way I'm living, you just leave the silly Rover boy 'lone!
Yeah, my PM box is full. If you want help, need parts, are on the ledge and need to be talked back, e-mail me at PT@PTSchram.com or call me at 260-804-0458.
If you don't like my attitude, I really don't care, but I will help you fix your truck anyway.
PTSchram is offline   Reply With Quote
Old 05-16-2010, 08:36 AM   #4 (permalink)
Toowild78's Avatar
Hey Mike,
106K on the clock and I have already installed a set 8mm Magnacor's about a year ago. I replaced the factory champs at 80k with a set of NGK iriduim's but have not been very pleased as the motor still had a slight mis. I went with the Champion double platinum's this morning and the motor smoothed right out. I'm a little shocked with the ngk plugs as I have used them several times in the past with good results. I even used them in my wife's merc twin spark. thanks for the replies, the plugs were $5.39each at NAPA.
Old 05-16-2010, 09:11 AM   #5 (permalink)
Administrator
After nearly 70,000 miles on my Plus 4's, I switched to Bosh Fushions while doing the head gaskets and I was not as pleased with them either, lost some low end puch that I had grown used to with the PLus 4's.
Need Parts?
Old 05-16-2010, 10:02 AM   #6 (permalink)
sweet home chicago
ArmyRover's Avatar
What he said.
"If you can't stand behind our soldiers, then by all means stand in front of them." unknown author.
Need Parts?
PT Schram pt@ptschram.com
paulgrant@mac.com
www.lucky8llc.com
http://lucky8llc.com/L8Forum/index.php
PM Marty(Drillbit)http://www.landroversonly.com/forums...o=newpm&u=5940
PM Original Rover Dude http://www.landroversonly.com/forums...do=newpm&u=708
1983 Land Rover 110 5 door wagon
1972 MGB
Old 05-16-2010, 05:17 PM   #7 (permalink)
Toowild78's Avatar
Well at at fisrt listen the mis was gone but after driving for a bit it's back only at idle. The new plugs perform better but still a mis at idle... Not sure what to do now. I can appreciate everyones opinon on the standard plugs but what I was looking for was long life. I have worked for NGK Spark Plugs USA for 14 years and the platinum and iridum plugs are a better option for 80~100k miles of service. The standard copper core start to fail during testing at 30k. Anyway no codes and going on vac. in a month any advice on where to check next? Also I use seafoam twice a year and the LR fuel treatment at every oil change 3k 15-40 Rotella K&N 3001hp. Thanks guys!!!
SEO by vBSEO 3.3.2
