Links
Old 09-01-2004, 06:42 PM   #1 (permalink)
Default Check Engine Light
I have a 2000 Disco Series II w/ 140K miles. THe Check Engine Soon light is on, and I was wondering if anyone can help in resetting it. Rumor has it only the dealer can reset after 1996 models.
Thanks for your help
scott is offline   Reply With Quote
Old 09-01-2004, 07:36 PM   #2 (permalink)
beer drinking member
dent's Avatar
not true.. any OBDII reader will be able to scan for the codes and reset the light... i would not suggest resetting the light without fixing what's broke though... you should be able to take it any shop and they'll be able to read and reset the code for you.
Or you can pick one up on ebay fairly cheap if you want to work on the car yourself... will pay for itself in no time
take care
sam
dent is offline   Reply With Quote
Old 09-01-2004, 08:01 PM   #3 (permalink)
Most likely cause is P1316, P0300, & P0305 - misfires (esp. cyl. #5) due to either a bad coil or valve stick.
Walk softly & carry a BIG SIX!
Steve83 is offline   Reply With Quote
