This is probably a foolish question but I recently purchased a 03 Disco HSE and the brakes are squeeking pretty bad, is there a way to check the pads and rotors without taking the tires off to see if they need replacing? If so what should I look for? Searched the forum but couldn't find an answer. Thanks for any help.
No there isn't.
You need to remove the wheels, if there is alot of brake dust that can cause the squeak as will cheap after market bake pads, no brake sound deadening material and glased pads and or rotors. How long have you had the truck, have you put brakes on it, what brand, how many miles on the truck? If they are squeaking too much you will throw your trio of lights and then things get interesting. Mike |
Hello disco mikei believe my rotors are warped because the steering wobbles when i'm breaking also they sqeeking like no other ++ i have the trio lights on. Would you recommend: 1) purchasing the rotor and brake kit from atlantic british and swap them. 2) resurface the ones i have now and just replace the pads. 3) take the car into the dealer for the brake and rotor job and the lights all together? I just purchased the vehicle 3 weeks ago and don't have a clue to what's really going on yet. Please advise. Thank You r.y. |
#4 (permalink) | |
got mud?
i just took my rover in to the dealer for that reason.. my back right break was squeaking REALLY loud.. and the lights came on when i hit the brakes to hard. its still at the dealer. ill be getting it back tomorow.
DII -- Pete 285/75 r16 Destination M/Ts |
#5 (permalink) | |
As for the brakes, yes, your rotors are warped, they can not be resurfaced and don't go to the dealer for brakes, your truck is easy to do a good brake job on for less then half of what the dealer charges. Mike |
| Thread Tools | |
| Display Modes | |
