Clicking noise?!?!? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 01-07-2011, 06:46 PM Thread Starter
tnelsonfla's Avatar
Quoted: 0 Post(s)
Question Clicking noise?!?!?
Hey guys I believe I have exhaust leak. I have checked the manifolds and seem to be tight. But the Rove only clicks under acceleration( it almost sounds like a baseball card in spokes) and after it has come up to temperature. It is a 1999 DII with 179000 miles. It is the original exhaust, I will craw under it tomorrow, is there specific sections I should check? and is there and easy method to use? Any advise is great thanks.
"A calm mind helps our human intelligence to assess the situation realistically"
***Tom
1999 Discovery II (190,500 as of 05-2012)
Palm Beach County Florida
Magnecor blue wires, Bosch Platinum plugs, 255/65-16 Bridgestone Dueler H/L Alenza, CDL from DI 1997, 180,000K service, Driveshaft Power front driveshaft.
tnelsonfla is offline
post #2 of 5 (permalink) Old 01-08-2011, 06:26 AM
Administrator
Quoted: 5 Post(s)
Crawl under, with a flash light and inspect all the seals and bolts, looking for a grey/black soot stain indicating a leak.
If you don't find one it is either internal like the valve train or a burned out head gasket shooting exhaust out the side of one cylinder.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 5 (permalink) Old 01-08-2011, 12:00 PM Thread Starter
tnelsonfla's Avatar
Quoted: 0 Post(s)
Hopefully you look at this again Mike...
Ok upon further review. There are no visible exhaust leaks on exhaust I went over all joint and clamps. I went back over all manifold bolts also. The noise is clearly on acceleration when the gas is released then noise stopped, or above 35-40.But if gas is held steady like at 55 noise returns. I also drove with moderate gas pedal and applied the brake and noise stopped immediately and when the brake was release and gas was held slightly on the noise returns. So my guess is brakes. I have Akebono pads ordered now that Advanced Auto has the 25% off special (code:BRAKE25), so I'll switch those out this week and see. If you think I should check anywhere else let me know.
***Tom
post #4 of 5 (permalink) Old 01-08-2011, 02:48 PM
Quoted: 0 Post(s)
Check bolts from manifold to pipe. I had clicking noise to, it was leak from joint. 1 bolt was snapped so each time pressure inside of manifold was rising gas was escaping with knocking sound.
Antibfs is offline
post #5 of 5 (permalink) Old 01-08-2011, 03:23 PM
Administrator
Quoted: 5 Post(s)
Sound like you have ruled out an exhaust leak leaving only the normal internal valve train issue which is not too hard to correct.
If you want some help with this, send me your number and I'll call you Sunday.
Need Parts?
Lucky8,
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Ratcheting/clicking noise. '03 HSE bergxu Range Rover P38, Mk III and Range Rover Sport 0 05-17-2010 07:47 AM
clicking noise alabamadisco 03 Discovery Series II 11 08-02-2009 06:39 AM
Clicking Noise tbc5star Discovery Series II 4 07-18-2009 03:05 PM
Clicking Noise in Engine beginer disco Discovery Series II 2 07-28-2008 02:04 PM
clicking noise and exhaust question greekdisco Discovery Series II 11 11-07-2006 03:26 PM
You may post new threads
You may post replies
