Old 06-29-2008, 03:12 PM   #1 (permalink)
Default Confused nervousness
Hi all I have a 04 disco with 86000 on the clock. Recently noticed ticking more often with the warm weather and all. So I just did a atf flush and oil change using 10w40 mobil 1. Still here ticking/clicking so I got under her to take a listen and I could here it well around the oil pan and surrounding area. I couldn't pin point where for sure or if the noise is just bouncing around down there or if it is coming from the oil pan or the tranny. Any thoughts would be greatly appreciated. Peace,Chris
cornbread is offline   Reply With Quote
Old 06-29-2008, 05:02 PM   #2 (permalink)
Are you sure it is not an exhaust leak?
Old 06-29-2008, 06:54 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I'm with Mike check the exhaust to y pipe joint and the manifold to head connection.
I'm guessing you'll find the culprit there
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 06-29-2008, 06:55 PM   #4 (permalink)
Mike, I'm pretty sure I've had 2 mechanics swear that it's a valvetrane noise. Plus before it got real hot here the noise was very hit or miss. One mechanic hit with the steth and said he heard nothing around the exhaust but could hear ticking on plenum. Chris
Old 07-01-2008, 08:12 AM   #5 (permalink)
brian4d's Avatar
Default Wouldn't that
Wouldn't that point to exhaust leak? After the engine gets hot it heats up and the metal expands sealing the leak? I had a manifold leak in my old 95 Pathfinder that had those symptoms. Yours is a tick, mine was a puff.
brian4d is offline   Reply With Quote
Very confused coldfrez Discovery Series II 1 03-27-2008 06:51 AM
Disco 2 tire decision - Very confused Figman Wheels and Tires 3 03-20-2008 07:45 PM
02 RR HSE GPS confused artcareer Range Rover P38, Mk III and Range Rover Sport 3 08-10-2007 05:16 PM
email from DAP iam confused help bama Discovery Series II 6 12-18-2006 11:49 AM
LE or LSE? sooo confused! errant Discovery Series I 4 10-02-2004 03:44 PM
