Looking to purchase this 2003 Disco that has coolant leaking out of the throttle body plate... that would not be a problem since I can fix that but there is also a constant leak from the coolant reservoir while the engine is running. Coolant leaks through the overflow hose. Would that indicate cylinder gasket problem or means that system needs to be bleeded?
Don't panic. First replace the coolant reservoir cap. As they age they lose the ability to hold pressure. They're ~$15 and available at any auto parts store.
Related Threads
507.6K posts
71.3K members
Since 2004
