Coolant smell, back of engine - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 04-19-2017, 12:14 PM Thread Starter
Quoted: 6 Post(s)
Hi All,
My D2 93k miles has a coolant smell that is coming from the back of the engine, no coolant drops when parked, and no obvious signs of the reservoir getting low, so the leak must be slight.
Looking behind the engine I see oilyness, but nothing that looks like a coolant leak.
Head gasket was changed (not by me) years ago at 65k miles, and engine runs strong, no oil in the rad.
should I;
Drain yucky orange stuff and replace it with nice green stuff and add a leak sealant
drain the yucky orange stuff and replace it with nice green stuff and add dye
Try not to smell the car so much
Hamhockracer is offline
post #2 of 9 (permalink) Old 04-19-2017, 12:46 PM
Drives like an old man
discomania04's Avatar
Quoted: 22 Post(s)
Garage
Option #4 sounds the best! In reality, the yucky orange stuff may be the cause. It's actually corrosive. Leak sealants rarely help and often hurt. I would go with option #3 , unless someone else knows something I don't (often the case).
2004 Disco II, bone stock, daily driver (gasp!)
discomania04 is offline
post #3 of 9 (permalink) Old 04-19-2017, 02:06 PM
Quoted: 233 Post(s)
Or... Option #5 . Get a pressure tester and find the leak.
If it's behind the engine, it's either head gaskets, an intake manifold leak or if on the right side, heater core in/out connectors (they're rubber)
CT090 is online now
post #4 of 9 (permalink) Old 04-19-2017, 02:18 PM Thread Starter
Quoted: 6 Post(s)
With my eyeballs?
And when I have the system pressured up I should just be looking with my eyeballs, for little leaks and stuff? it must be super hard to see something like that. Are there any pro tips I can apply when looking?
Thanks
post #5 of 9 (permalink) Old 04-19-2017, 07:02 PM
Quoted: 233 Post(s)
Jack it way up and crawl underneath. Get some bright lights and work mirrors on extensions. And patience. Or just wait. It's going to get worse.
Go out right now and get a temp gauge that plugs into your OBD port. The one on the dash is a decoration. Once it starts to move, your engine is already hurt. Scangauge is a favorite around here.
A little antifreese make s alot of smell. It's probably rolling down and hitting the windstream and spreading all over the underneath and evaporating. Whatever residue is probably blending in with your valve cover and oil pan leaks- they almost all have them.
CT090 is online now
post #6 of 9 (permalink) Old 04-20-2017, 10:08 AM Thread Starter
Quoted: 6 Post(s)
would a little bit of dye help? what is an ideal temperature range?
post #7 of 9 (permalink) Old 04-20-2017, 11:07 AM
Quoted: 233 Post(s)
Maybe. Never tried it. Leaks usually leak more when they're hot. Coolant isn't hard to spot. The undersides of these trucks are usually pretty oily and greasy. The water beads up on everything it's on.
Are you sure you don't just have a bad cap and are getting some splurt out of the drop tube off the tank?
CT090 is online now
post #8 of 9 (permalink) Old 04-24-2017, 10:04 AM Thread Starter
Quoted: 6 Post(s)
Smelly Smells
I might be, as in, the drop tube drippy drops and then splashes onto the firewall and smells back there. There do appear to be a few little drops at the end of the stick.
I have a little USB scope in the mail and I will see what it shows.
Thanks a bunch for the help!
post #9 of 9 (permalink) Old 04-24-2017, 10:52 AM
Quoted: 233 Post(s)
Best bet. Buy a new cap and pressure wash everything thoroughly. If your leak stops, you're golden. If it doesn't, it should be easier to find.
Those catch tanks can be problematic- they can crack and at first give you intermittent leaks.
CT090 is online now
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Coolant leak in back of engine sgsharris Range Rover Classic 11 03-14-2016 05:45 PM
Coolant smell while engine is warm DefenderTech Discovery 3 / LR3 9 05-09-2014 07:14 PM
Coolant Leak from back of Engine BlueDisco Discovery Series II 13 02-04-2013 02:16 PM
Loud Engine & Coolant smell in Cabin 04 Freelander HSE 2.5 ladybruja Freelander / LR2 2 12-08-2010 08:56 AM
coolant leak back of 4.6 engine Roverfriend Range Rover P38, Mk III and Range Rover Sport 6 09-24-2010 05:10 PM
You may post new threads
You may post replies
