Crank Angle Sensor same as Crankshaft Position Sensor ? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 12-27-2008, 08:51 AM Thread Starter
Quoted: 0 Post(s)
Is the Crank Angle Sensor the same as a Crankshaft Position Sensor ? I searched and I have all the symptoms of either a bad CPS or bad fuel pump. My 00 DII is shutting off while driving and while sitting at idle for a while, hazards come on, TC light comes on, sometimes SES lights up also but does not stay on and no codes are thrown. I have the extended warranty thru Great Lakes and it specifically says the Crank Angle Sensor is covered as well as the Fuel Pump, although I'm not sure either would qualify as having failed completely or a way to prove to the warranty company either needs replaced ? So far I have been able to get it running again by disconnecting the negative battery cable for about a minute then starts up fine. I don't think the inertia switch is being tripped, at least it is not popping up when this happens.
2000 DII SD7
DiscoIIDenver is offline
post #2 of 3 (permalink) Old 12-27-2008, 02:53 PM
Quoted: 0 Post(s)
I've got a bad cps, but I dont have the symptoms you do
85_305 is offline
post #3 of 3 (permalink) Old 12-27-2008, 06:17 PM
Quoted: 0 Post(s)
I'm not a dedicated Land Rover tech but yes the Crank angle sensor should be the same as crank position.
If the fuel pump was/is going bad the truck would stumble to a stall, not die like the key is shut off. The CKP sensor does act like that and will restart after it's allowed to cool off. It's a basic Hall effect sensor that uses magnetic fields to see crank speed. Next time, simply wait the 10 minutes...then try to restart.
I'd expect the CKP sensor to show a fault however.
Randy P is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
User Tag List
Linear Mode Linear Mode
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 5 01-17-2015 06:46 PM
crank position sensor wimp Discovery Series II 2 12-01-2008 05:39 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 06:00 AM
Crank Position Sensor location Crazy Craig Discovery Series II 10 12-28-2006 04:03 PM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 08:16 AM
You may post new threads
You may post replies
