» Sponsors
» Sponsors
Old 12-22-2008, 12:44 AM   #1 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
Question Crank Case Sensor
How big a job is it to change a crank case sensor on my 2002 Discovery II SE
Thanks,
Landy II
My Ride - 2002 Discovery II - Stock And Going To Stay That Way
LandyII is offline   Reply With Quote
Old 12-22-2008, 04:47 AM   #2 (permalink)
Super Moderator
For many people I have spoken with, once you find it, it is a pretty quick job, 15 minutes or so.
Old 12-22-2008, 08:09 AM   #3 (permalink)
Product of Cvcimia
slangel's Avatar
It is not hard at all, you will see it's location on the rave cd, very simple to do!
I tried to see things from your point of view, but I couldn't get my head that far up my ass.
I think Cvc's goal is to make me vomit daily with his disgusting avatars.
slangel is offline   Reply With Quote
Old 12-28-2008, 12:58 PM   #4 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
Ahhh, I'm having trouble finding it on the RAVE CD ;-(
Anyone know what page it's on? I'm going to try and tackle this today
Old 12-28-2008, 01:30 PM   #5 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
If it's under Electrical System, I'm baffled...
Old 01-04-2009, 10:20 PM   #6 (permalink)
I was just looking at this on the Rave CD, in the Workshop manual it is under the Engine Management System - V8 section then under Repairs it shows as 'Sensor - crankshaft position (CKP)' There is also some information in the same section under Description - Engine Management. I thought I had a bad Crankshaft Sensor but turns it out it was just a loose connection to the inertia switch, which was shutting the engine off.
2000 DII SD7
DiscoIIDenver is offline   Reply With Quote
Old 01-06-2009, 12:22 AM   #7 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
Thanks, I found it on page 382/1529
crank position sensor wimp Discovery Series II 2 12-01-2008 07:39 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
Crank Position Sensor location Crazy Craig Discovery Series II 10 12-28-2006 06:03 PM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
