» Sponsors
» Sponsors
Old 10-07-2008, 07:30 PM   #1 (permalink)
leewood
Default Cruise Control and Fuel Economy
I have heard that using cruise control in other vehicles helps improve your mpg, I just got my disco and I have used the cruise control a few times and noticed that it 'jumps' a lot. It accelerates rapidly than other cars i have driven. does anyone know if using the cruise control in the disco helps save fuel?
lh296906 is offline   Reply With Quote
Old 10-08-2008, 06:13 AM   #2 (permalink)
Super Moderator
At what speeds are you using it at?
You may have a vacuum leak causing it to fail or your vacuum pump may be going bad.
What year is the thruck?
Old 10-08-2008, 06:34 AM   #3 (permalink)
leewood
its a 2003, I use the cruise on the highway so around 60 to 70 mph
Old 10-08-2008, 07:24 AM   #4 (permalink)
naterover's Avatar
Keeping your RPM low on the highway is what keeps your MPG down and since your cruise control is only concerned with how fast your going and not really caring what RPM it takes to keep your speed consistant using you cruz is not a good way to save gas.
also it doesnt have anything to do with your cruise and i cant site my source because
i forgot where i read it but i read you can raise your MPG on the highway by not going any faster than 65mph.
"It takes a big man to cry, but it takes a bigger man to laugh at that man."
Nathan Pedigo
00' Land Rover Discovery II SE7
naterover is offline   Reply With Quote
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 21 04-02-2009 10:05 AM
When considering extended warranty on a 2002, what coverages are most important? JamesBahn Range Rover P38, Mk III and Range Rover Sport 0 04-30-2008 04:15 PM
Ethanol Pascaltissot Range Rover P38, Mk III and Range Rover Sport 3 05-24-2007 11:24 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
looking for an electronic fuel engine control unit krigtt198 Land Rover Parts and Vehicles Wanted 2 09-08-2005 06:17 AM
