Cruise Control Never Worked - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 12 (permalink) Old 12-22-2008, 06:18 PM Thread Starter
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
Cruise Control Had Never Worked
Besides the Hella Fog Lamps not workinhg (another thread) I have never been able to get the Cruise Control working on my 2002 Disco II
What are somethings that would prevent a Cruise Control from working properly?
Thanks,
Landy II
2002 Discovery II Kalahari Edition - Stock And Going To Stay That Way
Towing a 2014 Lance 1685 Travel Trailer
Prodigy 3 Brake Controller
Fastway e2 Hitch
Absolutely NO problems
LandyII is offline
post #2 of 12 (permalink) Old 12-22-2008, 06:47 PM
Quoted: 0 Post(s)
Landy Girl :C.C. issue
Search threads, this is common. Check for a vaccum leak(worn rubber hose) under hood. Easy fix.
1999 Disco
2004 Disco Bodie
" If it aint leak'n oil....she's outta oil !"
Bodie is offline
post #3 of 12 (permalink) Old 12-23-2008, 03:00 AM
Product of Cvcimia
slangel's Avatar
Quoted: 0 Post(s)
Yeah might as well replace the hose Lauren, not so hard to do, I had to do mine.
I tried to see things from your point of view, but I couldn't get my head that far up my ass.
I think Cvc's goal is to make me vomit daily with his disgusting avatars.
slangel is offline
post #4 of 12 (permalink) Old 12-23-2008, 04:31 AM
Administrator
Quoted: 5 Post(s)
Also, does the cruise control switch light up when you turn it on, if so I agree replace the vacuum lines.
Disco Mike is offline
post #5 of 12 (permalink) Old 12-23-2008, 05:09 AM
tyl604's Avatar
Quoted: 47 Post(s)
Just open the hood and look underneath just at the back of the wheel well. You will see the rubber vac hoses. I finally took a look at my daughter's car after two years and it took almost five minutes to fix.
tyl604 is online now
post #6 of 12 (permalink) Old 12-23-2008, 03:03 PM Thread Starter
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
No light when I turn it on. Ive got the Rave CD to look up where the vaccum line is. Maybe another problem to take to my local Land Rover guy and have him trouble shoot it, but I'll do the fix
I'm taking the Hella fog light problem to him and I'll see what he says about the cruise control. Maybe it's a problem that he can point out and I'l do the fixing on!
Fastway e2 Hitch
LandyII is offline
post #7 of 12 (permalink) Old 12-27-2008, 01:56 PM Thread Starter
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
Originally Posted by LandyII View Post
No light when I turn it on. Ive got the Rave CD to look up where the vacuum line is. Maybe another problem to take to my local Land Rover guy and have him trouble shoot it, but I'll do the fix
Fixed it myself - easy as pie! Vacuum line!
Fastway e2 Hitch
LandyII is offline
post #8 of 12 (permalink) Old 04-21-2009, 12:12 PM
Like getting punched in the face by a guy wearing pink brass knuckles
Quoted: 0 Post(s)
My cruise control light comes on, but nothing happens with the controls...vacuum line also?
Where are the vacuum lines located? It's the last line item on my laundry list to get this thing back to full working order.
You should drive a hybrid...
I need the gas.
Have you ever sat on the edge of the bed with one shoe on and wondered if you were getting ready for work or going to bed?
MARGRETTE is offline
post #9 of 12 (permalink) Old 04-21-2009, 02:14 PM
Administrator
Quoted: 5 Post(s)
One main one going to the second brake type switch at the brake pedal the rest are at the pump behind the fuse block in the engine compartment.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
post #10 of 12 (permalink) Old 04-21-2009, 04:45 PM
Quoted: 0 Post(s)
I found a line that hooks to a diaphram that seems like it is supposed to be hooked to the forward throttle cable. There is a 1/4" gap betweent the two at the moment. Vacuum line that hooks to the back of the diaphram is in good shape. It looks like there is an open fitting at the bottom of the canister that the line starts from...maybe that canister has no vacuum becasue of the open fitting...or is the throttle cable supposed to be attached to the diaphram. Don't have my camera available until Friday, but I can try to take some pics with my phone to show what I am talking about.
I need the gas.
post #11 of 12 (permalink) Old 08-02-2009, 02:00 PM
Quoted: 0 Post(s)
I just found my diaphragm and the vacuum hose is missing there was a small 1/2 cm rubber cable that was perished pretty bad, where should this hook up to?
I just figured it out from looking at the RAVE there is the unit underneath, however I had no cable present other than a nice perished 1/2 cm piece of rubber on the back of the diaphragm. Thanks all
Last edited by marshcroft; 08-02-2009 at 02:10 PM. Reason: answered my own question.
marshcroft is offline
post #12 of 12 (permalink) Old 08-22-2010, 07:15 PM
pac99's Avatar
Quoted: 0 Post(s)
Wow, 6 months with no cruise, and within 10 min of reading this thread it works great!
Vacuum lines the culprit, and knowing where they are... priceless.
Thanks all
pac99 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Cruise Control Vac Hose route? TennRover Discovery Series II 6 08-27-2010 02:33 PM
Cruise Control and Fuel Economy lh296906 Discovery Series II 3 10-08-2008 05:24 AM
Cruise control not working. Phlawed Discovery Series II 7 04-14-2008 02:35 AM
Cruise Control Help Disco Truck Discovery Series I 6 03-26-2007 09:16 PM
Cruise Control gdom88 Discovery Series II 2 01-09-2005 04:04 PM
You may post new threads
You may post replies
