» Sponsors
» Sponsors
Old 04-05-2008, 06:55 PM   #1 (permalink)
Phlawed's Avatar
Default Cruise control not working.
My cruise control went out awhile back. After getting under the hood a few months ago I found a bad vacuum hose that was going into the Cruise control. Well I pulled the hose and replaced it a new hose and clamped it on. I took it out for a test and still no cruise. It felt like it tried to engage a few times but never would agian. Any ideas on what else could be long or what to maybe look for.
2000 Land Rover Disco II
1969 Ford Mustang (under resto)
Phlawed is offline   Reply With Quote
Old 04-05-2008, 06:57 PM   #2 (permalink)
you sure you didnt hook it up wrong.
but if you did it right, then you need to hook up testbook to see what the switches are doing.
Old 04-05-2008, 07:19 PM   #3 (permalink)
Super Moderator
I think there are 4 hoses to replace.
Old 04-07-2008, 12:17 AM   #4 (permalink)
garywinter's Avatar
Default Cruisin Again
My 99 Disco had exactly the same problem.
I checked the swithch on the clutch pedal. The switch needed to be adjusted. While checking the switches, check the one on the brake pedal.
Hope this helps
99 Discovery 2 XS V8
Coils Replaced Air Bags
Mod on Front Bumper
Dastek Unichip
BFG All-Terrain Tyres
garywinter is offline   Reply With Quote
Old 04-07-2008, 02:25 PM   #5 (permalink)
Adventurous Land Rovers and Jeeps
sirchadd's Avatar
Check the cable adjustment for throttle and cruise control, not adjusted correctly may cause that concern.
Just a thought.
sirchadd is offline   Reply With Quote
Old 04-13-2008, 09:27 AM   #6 (permalink)
Phlawed's Avatar
clutch switches? where would those be located
Old 04-14-2008, 12:26 AM   #7 (permalink)
garywinter's Avatar
Look under the drivers side by the pedals, just above the pedals there is a cover that hides all the wiring. Remove this cover and you will see on the brake pedal there is a switch that activates the brake lights. The clutch has the same sort of switch. The switches can be adjusted. Remove the switch. Pull the shaft out of the switch but be carefull not to pull it all the way out of the unit. The switch has a ratchet mechanism in it.
Mod on Front Bumper
Dastek Unichip
Old 04-14-2008, 04:35 AM   #8 (permalink)
Roverhound's Avatar
You don't have a 5 speed transmission therefore you won't have a clutch switch.
It just doesn't matter.
It's not like I am going to do this without asking my mom first.
1996 D1 Cruise Control not working- any ideas how to fix? Adam in NYC USA Discovery Series I 4 12-21-2007 07:18 AM
Cruise Control Help Disco Truck Discovery Series I 6 03-26-2007 11:16 PM
Cruise control - slowly stopped working NiagaraRover Discovery Series II 4 08-01-2006 11:42 AM
Cruise control on manual TD5 2004 dfe Discovery Series II 4 01-19-2005 05:05 PM
Cruise Control gdom88 Discovery Series II 2 01-09-2005 06:04 PM
