Links
Old 05-09-2008, 08:39 AM   #1 (permalink)
R_Lefebvre's Avatar
Default D2 Stock Spring Rates?
Anybody know what the stock spring rate is on a D2? Length too would be great. Just curious... Trying to figure out what springs to get for my truck. The goal is support a winch bumper and cargo loads, while not lifting the truck much. I'd like to only raise it 1", not 2+.
Alternatively, if somebody could give me a photo, wire diameter and coil diameter I can calculate it... roughly.
R_Lefebvre is offline   Reply With Quote
Old 05-09-2008, 09:29 AM   #2 (permalink)
actually it goes by color on the springs.
I know no disco one you need new front springs. Not sure if you need new ones for a regular disco two.
I dont believe you do. last winch install didnt need different coils.
check with your local parts dept. If you own a 99-2003 its not a bad to install upgraded springs cause the front springs are known to break. I install them at least once a month.
Old 05-09-2008, 01:36 PM   #3 (permalink)
You can not buy OME or RTE springs that will only raise one inch, 2"s plus is the norm.
If you are going off where you need a bumper and a winch you want a little more lift.
Your truck has already dropped an inch or more since new, Rover coils never held up well, so a 2" OME lift is only going to be an inch taller then new.
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 09:55 PM
2 spring rates stock? happytrails Range Rover Classic 1 09-25-2007 02:44 PM
Springs: retention or cones? SCSL Off Road 171 12-09-2006 04:04 PM
Springs: Inquiring mind within... yieldsign2 Range Rover Classic 8 03-15-2006 09:57 PM
Defender 90 V8 spring rates Robin Brown Defender 0 12-29-2004 09:31 AM
