Old 05-14-2008, 12:23 PM   #1 (permalink)
Default Disco 2 Electrical Problem
Hi,
I'm new to this forum game so forgive me if i get things in the wrong place etc. I have a 2000 Disco 2 with a frustrating electrical problem.
Start the motor, run for 3 minutes and the radio plus front and rear wiper and washers cut out. Keep running for a further 5 minutes and the wipers/radio will come back on.....3 minutes later they die. If i just switch on the ignition without starting the engine both wipers/radio work fine for as long as you like....crank the engine and they die !!!. I removed the BCU and made sure it was dry...roasted it with a hair dryer..replaced it... no change. Any ideas where to go next?
Wiltshire disco2 is offline   Reply With Quote
Old 05-14-2008, 02:46 PM   #2 (permalink)
Outside of Wiltshire !
buick215 is offline   Reply With Quote
Old 05-14-2008, 07:09 PM   #3 (permalink)
malamute's Avatar
Originally Posted by Wiltshire disco2 View Post
Hi,
Make sure that after you start the engine the key cylinder goes back a notch to the run position. It's smart enough to stop running the starter after the engine is running. I didn't last 5 minutes before I pulled over shut the car off, and everything went back to normal. I just don't trust that return spring anymore.
Matthew
malamute is offline   Reply With Quote
My trail-ready Disco I for your stock Disco II chelo Land Rover Vehicles 0 11-18-2007 09:55 PM
Problem with MY99 Disco Gate7 Discovery Series II 14 11-11-2007 01:06 AM
a little help please..ignition, fuel or electrical problem? Ramathorn Discovery Series I 0 08-25-2007 04:45 PM
New Member - Electrical Problem WetDawg Discovery Series I 5 03-23-2005 09:36 AM
More Disco Electrical Problems... taylorbob1 Discovery Series I 1 11-16-2004 09:29 PM
