I posted this on Sollihul as well but wanted to get as much info as I can.
I read on on this site that I could "have a shop rebuild" my front drive shaft instead of replacing it. I wish I had a side by side comparison so I could know what needs to be "rebuild" to make the shaft serviceable. And if it requires a shop, what exactly am I asking that shop to do with my existing drive shaft? Does anyone have any tips about this? |
Having them put new, servicable ujoints on it. Check out Tom Wood's land rover page to see what they are doing to them: http://www.4xshaft.com/Landrover.html
Thanks for the reply.
I just broke down and ordered the one from British Pacific. It was on sale today/yesterday. |
All the shop needs to do is rebuild the double cardon joint, constant velocity joint, which basicly means to remove and replace both u-joints with serviciable joints, check and replace the center ball if needed and put it back together.
You should also buy 2 jerks, one for each drive shafts slip sleeve, install them and lube them. Mike |
Sorry to ask a silly question, but what are jerks. I was checking on prices to rebuild my driveshaft, and my mechanic has never heard of them. It was also an awkward moment with the smirks I got. Please enlighten
#7 (permalink) | |
Zerks: grease fittings I would imagine they did smirk at the shop Dan BTW: When I did mine, I also replaced the u-joint on the rear of the front shaft. |
#8 (permalink) | |
I have wondered about the addition of the zerks for the spline (slip sleeve) on mine. Wondering if it could possibly cause balance issues. I have seen how small some of the little pieces of metal welded on for balance are, and it seems that a zerk is not much less mass (and it hangs out more). Just a thought. Peace, Dan |
#9 (permalink) | |
I did notice when I replaced my front shaft (after it broke on the Double Cardon) that there is a spot for a grease nipple on the shaft Might be worth installing one to grease the shaft then remove it to maintain factory balance
Gordon T. Smith Middle East Land Rover Nutter |
#10 (permalink) | |
Install, grease, then remove.
www.mvlrs.com |
#11 (permalink) | |
Mike |
