Old 03-11-2008, 02:58 PM   #1 (permalink)
Question Disco 2 - TC & HDC fault lamps lit
Hi there!
I have one of those strange (but very typical to me) situations on my disco 2. TC and HDC fault lamps are lit up. The diagnostic computer states that I have a problem with the data line from engine ECu to ABS ECU. I cancelled the faults and this data is now present. However, as soon as I start the engine, this fault re-occurs. I have plugged in an oscilloscope and could see a square wave on both ends of the wire that transmits this data (even though I do not actually know how this wave should look). The ABS function works perfectly.
Did anyone ever come across this problem? Any ideas what else I can check? THanks & good day to all. R :-)
rpbonnici is offline   Reply With Quote
Old 03-11-2008, 04:08 PM   #2 (permalink)
If you were to do a search on any of the Rover forums, this one included, you would find hundreds of old post on this exact subject. This is considered a D2 most common problem.
Once you read thru some of these, shout with any specific questions.
Code 1176 Maximum Positive FMFR Correction Fault Disco I wade Discovery Series I 9 04-24-2008 03:14 PM
96 Disco MAF and fog lamps roverpwr Land Rover Parts and Accessories 1 07-20-2007 08:09 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
