Old 09-16-2005, 10:30 PM   #1 (permalink)
Default disco II hesiation
Hey everyone, this is a great site with plenty of helpful people. I’ve learned a lot reading past replies. However I finally have a question of my own.
I have a 1999 Disco II, which has a hesitation at low rpm’s, usually when starting out from a stop. Some times it hesitates at part throttle during acceleration. Once or twice it has even backfired.
I have replaced the plugs, air filter, changed oil and filter, began using a higher octane fuel, all to now avail. It seems like a fuel problem to me. However it could be a sensor acting up. No check engine lights or service engine soon lights. There are no codes to read. I just found out that there is no external fuel filter to change.
So, the question is…Where do I look next. If anyone has any knowledge of this type of problem, I would like to know what you did to sort it out. Could It could possibly be an in-tank filter prob? Please be as detailed as possible.
Thanks again for all the help.
Cheers
mecha_sky is offline   Reply With Quote
Old 09-16-2005, 10:54 PM   #2 (permalink)
It sounds like you might have a clog or bad injectors, try running sea foam though a tank of gas to see if that clears out your injector, or you can get a fuel system cleaning from brakemasters, jiffylube, or some place like that.
AzCamel is offline   Reply With Quote
Old 09-17-2005, 12:29 AM   #3 (permalink)
Nacho Libre
Hailsharky's Avatar
When was teh last time your fuel filter was changed?
Hailsharky is offline   Reply With Quote
Old 09-17-2005, 01:10 AM   #4 (permalink)
Default fuel filter changed last
Well, I had suspected that the fuel filter might need changing, so I went to the local parts house, and they sold me an inline fule filter for a disco II. I took it home and searched all over for the filter, and could not find one. I read past posts on this site, and discovered that my discovery does not have an inline filter.
To answer your question, I have never replaced the intank filter. I just purchased this machine a few months ago, and suspec that the previous, origonal owner, never changed it either.
Old 09-17-2005, 01:12 AM   #5 (permalink)
Sea Foam? is that a product name?
Old 09-17-2005, 06:08 PM   #6 (permalink)
yeah, i used it in my car and motorcycle, every 15k. Some of the member here swear by it also, i'd give it a shot.
