I have a 2002 Disco II with 18" rims. I want to put bigger off road tires on it and need to lift a minimum of 2". I have been looking at coil spring spacers to use with the stock coils and the OME coil upgrades available.
Anyone have luck with spacers or should I just go with an OME kit? Thanks Shawn
1995 AA Yellow D90 |
I used the the OME heavy-duty springs on my Discovery. (96') I got the most HD spring that I could find @ the time as I have plans of hanging alot of heavy equipment on it. It raised it enough that I wore out the second rotoflex joint in about 6 weeks. I put in a u-jointed driveshaft @ that point & have had no trouble since. I now plan to put in some spacer blocks, but I need to change to longer brake lines first. The ride is still comfortable, although stiffer, but it really hauls a load well. Do you have the air ride rear suspension or ace? I'm sure that would make a difference in what you would be able to do. Thank You, LRW
#3 (permalink) | |
I seem have the only SE7 without the air ride/ace... Doe this make a difference when selecting a lift?
Spacers do nothing to improve the ride both on or off road, all they do is lift the vehicle on it's old tired shocks and springs. None of the people I wheel with use spacers unless they have already gone to springs and shocks first because they don't help off the road.
Go to OME's, like 751 front colis and their rear equals and get the lift you are looking for as well as a much better ride. Mike J. |
| Thread Tools | |
| Display Modes | |
