Old 02-01-2007, 10:46 AM   #1 (permalink)
Default Disco II Oil pressure warning light
The oil pressure warning light on my 2003 Disco V8 (Auto) lights up every time that the vehicle is stationary, when driving the light goes out again.
It seems that the moment the rpm exceeds 600rpm, the warning light goes off.
The oil level is OK, don't know what could be wrong - Any suggestions
mcenery is offline   Reply With Quote
Old 02-01-2007, 11:09 AM   #2 (permalink)
Dan Erickson's Avatar
You may first want to do a check with a pressure gauge to see what the pressure actually is.
This can be done by removing the pressure switch and installing the gauge.
It should be about 50psi at 2000 RPM.
You could also have this done at an independent shop or at the dealer.
Ron Paul:
The most Constitutional “Bang for the Buck” you’re going to get.
www.ronpaul2008.com
www.mvlrs.com
Dan Erickson is offline   Reply With Quote
Old 02-01-2007, 11:19 AM   #3 (permalink)
Thanks, will have it tested over the weekend at the local dealer.
Old 02-01-2007, 01:46 PM   #4 (permalink)
03's are know for having failing oil pumps hence blown motors, don't screw with it or drive it much till you get it checked or you will have a hug repair bill for buying a new engine.
