Disco II Overheating when I run AC or Heat - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-12-2012, 11:29 AM   #1 (permalink)
Default Disco II Overheating when I run AC or Heat
When I run my AC or Heat im leaking coolant and over heating. But if I don't run the AC or Heat, no coolant loss and no overheating. It's been about a month driving around with no coolant loss without running AC or heat. Any idea of the problem?
jlweaver1 is offline   Reply With Quote
Old 11-12-2012, 11:47 AM   #2 (permalink)
'03 Disco SE
Bosnian Discovery's Avatar
Help us help you. Where does the coolant leak from? How much coolant did you lose? What temperatures did you see?
The AC and Heat are two completely unrelated systems - the AC uses a compressor, condenser, and evaporator to cool the air while the HEAT uses a mini-radiator-like heater core behind the dash to heat the air. The AC system does not directly use the coolant and therefore should not make it leak. The only thing I can think of is that your expansion tank cap is failing causing the system to either lose or gain pressure when your'e using the HVAC system.
Bosnian Discovery is offline   Reply With Quote
Old 11-13-2012, 06:28 AM   #3 (permalink)
Administrator
Do a coolant pressure test to find the leak then get back to us.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Will a Discovery II heat/ac control unit work in a Disco I LRDisco97US Discovery Series I 3 02-06-2009 03:29 PM
I had no Heat, had my heater core flushed. Heat is back! SafariDave Discovery Series II 6 02-04-2009 10:52 AM
'99 Disco II - no heat through AC ducts??? tyl604 Discovery Series II 9 01-14-2009 12:11 PM
No heat disco 2 98cruiser Discovery Series II 6 01-08-2009 07:43 AM
Bucking Disco and heat problem BlueDisco Discovery Series II 3 02-13-2007 08:27 AM
SEO by vBSEO 3.3.2
