Old 01-28-2006, 03:36 PM   #1 (permalink)
2000DiscoII
2000discoII's Avatar
Post Disco II Shock installation
New Owner, used Disco II. Any tips on front shock installation? Do I have to remove the bell tower upper mount, or compress the coil spring? Any help is appreciated. I looked on the forum and other sites, but can't find anything for the 2000 year model.
2000 Discovery II
2000discoII is offline   Reply With Quote
Old 01-28-2006, 04:32 PM   #2 (permalink)
Compress the coil spring--notice the two bolt holes at the bottom of your shocks. Besides fastening the lower end of the front shocks, the lower shock bolts also hold the lower spring perch to the axle. So you need to unload the spring tension to line up the lower perch bolt holes anyway.
O.B. is offline   Reply With Quote
Old 01-28-2006, 05:00 PM   #3 (permalink)
2000DiscoII
Thanks for you quick response!!
Old 01-28-2006, 08:05 PM   #4 (permalink)
You can jack up one side of the front axle, compressing the spring and shock and then pull the top of the shock tower, unhook the top shock mount then the lower mount, remove the shock and installing the new one going thru the same steps backwards.
Thats how I do them and it is real quick and safe. What brand of shock are you going to install?
Mike J.
Old 02-04-2006, 12:38 PM   #5 (permalink)
2000DiscoII
Thumbs up Thank You
Many thanks to those who responded to my OME shock installation question. Just finished up, one hour, five minutes. Great to have this forum to ask questions. Now I'm waiting for my Nerf bars, Brush Guard, and cargo rack to arrive. Thanks again.
JD Bush
