Disco II sudden valve train noise - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-21-2012, 07:56 PM   #1 (permalink)
Default Disco II sudden valve train noise
Ok so my wife's truck developed some sudden and significant valve train noise. Not uncommon from what I have been reading. The " ticking" or in this case more like rattling was only on the passenger side of the engine, that became more of a whine when revved. I have removed the valve covers, and there is nothing obviously loose or broken. I have pulled the plugs and again they look fine. Compression is between 150 and 160 on all 8 cylinders. 156 k miles. Some sludge is visible.
So here are my questions.
1 is this the lifters, or could this be a bad oil pump.
And how do I test the oil pump?
2 I'm going to do the lifters and camshaft any way. It's time. Do I need to replace the camshaft bearings, and rocker assembly's?
3 without doing a total rebuild what else should be done while I have it open?
BugSplatter is offline   Reply With Quote
Old 11-22-2012, 07:18 AM   #2 (permalink)
Administrator
You should have checked our oil pressure first. That being said, and the engine apart, pull the front covers and inspect the pump, you most likely have a broken oil pump ring.
If you want some help on this, send me your number and I'll call you.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 11-22-2012, 07:47 AM   #3 (permalink)
I forgot a bit of info. It's is a 1999 discovery II, and the oil light never came on. I will let you know when I get to the oil pump.
Old 11-22-2012, 08:48 AM   #4 (permalink)
Administrator
Read the 2 sticks at the top of the D2 section so you know what to look for regarding valve train noise.
Need Parts?
Old 11-22-2012, 04:05 PM   #5 (permalink)
What I thought was valve train noise on the passenger side only turned out to be a loose exhaust manifold. Might try tightening that before digging into the engine.
loganpendergraft is offline   Reply With Quote
Old 11-26-2012, 10:57 AM   #6 (permalink)
Ok so I'm finally down to the oil pump and it all looks good. I did find that on the way into the engine that intake manifold,valve cover, and oil pan bolts were all loose or not torqued.
I'd
Is This timing chain too loose?
Any other thoughts before I order parts, and start re assembly?
Old 11-26-2012, 10:58 AM   #7 (permalink)
Ring gear photo.
Old 11-28-2012, 01:25 PM   #8 (permalink)
GreenGiant's Avatar
I'd
Timing chain slack reminds me of my own at 162K when I replaced it. The replacement chain was much tighter, but this was my experience; others with more experience should chime in. Were I faced with the picture you posted, I would replace the chain and gear set before reassembly.
"Statistics are used as a drunken man uses a lamp post — for support rather than illumination."
GreenGiant is offline   Reply With Quote
Old 11-29-2012, 08:17 AM   #9 (permalink)
you need to take the back plate off the oil pump it's the other ring gear you can't see that breaks....
agthird is offline   Reply With Quote
A"MUST Read For Anyone About to Repair a Head Gaskets or a Valve Train Noise. Disco Mike Discovery Series II 20 04-09-2013 08:35 PM
A 2nd. Must Read for Any and All Valve train noise Disco Mike Discovery Series II 4 02-22-2013 09:43 PM
A"MUST Read For Anyone Who is About to Repair Head Gaskets or a Valve Train Noise Disco Mike Discovery Series I 19 12-22-2012 06:57 PM
Oil light and valve train noise kc2irv Discovery Series II 2 11-21-2011 09:53 AM
Valve Train Noise - Questions after Sticky Read TheGreenTank Discovery Series II 5 07-31-2011 02:11 PM
SEO by vBSEO 3.3.2
