disco II suspention & lift - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 02-14-2013, 01:49 PM   #1 (permalink)
'03 dII magnaflow exhaust
Default disco II suspention & lift
wondering if anyone knew of the best brands or kits for lifting and upgrading suspention on my '03 dII ?
jakeman is offline   Reply With Quote
Old 02-14-2013, 02:54 PM   #2 (permalink)
Administrator
Old Man Emu or RTE.
How tall a lift are you looking for, what sort of wheeling are you planning on doing?
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 02-14-2013, 05:33 PM   #3 (permalink)
well im doing alot of off roading in the mountians of new york over downed trees river beds mountian/ logging roads and up steep grades
Old 02-14-2013, 05:59 PM   #4 (permalink)
Administrator
So, how tall a lift and how big a tire?
Have you already rebuilt your front drive shaft? Any plans for gearing, bumpers or a winch? All these thing will help you pick the right height lift.
Need Parts?
Old 02-14-2013, 09:39 PM   #5 (permalink)
grades
There are several manufacturers that provide a basic shock/spring kit that will get you a 2" sping lift. That's probably a good place to start as its a straightforward ride height lift without any complications. You can run an aggressive tire with that setup, such as a BFG Mud Terrain 265/75R16. This config is all that the vast majority of people need. That's all I've got on my rig and I run pretty much everything in Moab with it. You don't need a massive lift to be effective.
Moreover, you need not worry about all of the follow-on changes that are required if you start going with a 3" or bigger lift and larger tires (read: heavier), which, quite frankly, are significant if you plan on doing it properly. With the kits mentioned above I think the most you will need to decide is if you want a medium or heavy duty spring in the kit, and that's about it. So if you're not really sure how much you want to change, this is a pretty cost effective starting point.
I have recently had the Terra Firma heavy duty kit on mine and would not recommend it. Started fine, but the back shocks were pretty much toast after 15,000km. Granted that was a lot of serious offroading, but I'm pretty gentle on the vehicle so they should not have deteriorated at that rate They also fade noticably in very hot conditions.
OME is probably a safer bet.
Soph is offline   Reply With Quote
Tire & suspention advice needed clayrobinson Discovery Series II 7 05-17-2011 10:35 AM
03 lift kit &tires'&rims beach runner Wheels and Tires 0 03-05-2011 04:10 PM
OME suspention PeteRice Discovery Series II 3 01-10-2011 04:59 PM
Suspention in! PeteRice Discovery Series II 0 03-29-2008 03:51 PM
2" Suspension Lift, Spring Conversion & Headers - Parts & Recommendations?? *PICS* Jigsaw89 Range Rover Classic 27 11-17-2007 01:05 AM
SEO by vBSEO 3.3.2
