» Sponsors
» Sponsors
Old 07-01-2009, 05:09 AM   #1 (permalink)
Default Disco Mass Air Flow
How do you know when your Mass Airflow Sensor is dead? My car will only run at low idle. Could this be TPS or MAF?
laker072 is offline   Reply With Quote
Old 07-01-2009, 05:40 AM   #2 (permalink)
Rover Driver
tcpfl's Avatar
Either one of those sensors will throw a code when bad. Get your codes read and see what it is.
Tom
2006 LR3 SE - Stock except for 255/60/18 General AT2s
2004 Disco II SE - 3" OME HD Springs/Shocks, Borla Cat-Back Exhaust, My Front Shaft Is A Woody, ARB Sidesteps, 255/60/18 General AT2s
2001 Disco II SE - Sold
tcpfl is offline   Reply With Quote
Old 07-01-2009, 06:08 AM   #3 (permalink)
Super Moderator
You need to be more specific, what year, how many miles, how low and when and do you have a check engine light on?
Old 07-01-2009, 06:03 PM   #4 (permalink)
That code is not present, but the ECU currently installed in the truck is for the wrong year and the wrong engine...... This is becoming a real head ache!!
Old 07-01-2009, 08:36 PM   #5 (permalink)
2002 Discovery II SE
Alak's Avatar
So, your ECU is from a truck from the wrong year and the wrong engine thats currently in your truck and it runs poorly?
2002 Discovery Series II SE. 2" OME Heavy Duty. 265/65R18 BF Goodrich All-Terrain T/A's. Warn XD9000i on Homemade Bumper.
Alak is offline   Reply With Quote
Old 07-02-2009, 05:11 AM   #6 (permalink)
That's correct. I bought the truck that way and didn't find out until after I had done a tune up and my local - non-rover mechanic could not figure out the reason it was running rough. None of the fault codes made sense, so I headed to the dealers. They made the discovery on the Discovery (har, har).
Last night I downloaded the service manual and the condition points to the MAF, but still no code.
Old 07-02-2009, 06:33 AM   #7 (permalink)
Super Moderator
So what exactly is the truck doing wrong?
By the way, there are 4 MAF codes and they rarely ever come up when the MAF is dead. Normally you will get either lean or rich codes for both banks, your exhaust will smell, either 3rd or 4th gear will have a shifting issue and your performance will fall off.
Old 07-02-2009, 09:48 AM   #8 (permalink)
2000 Land Rover Bushrangie
Bushranger's Avatar
Gallery: 4
Does anyone on here know whay a Series 1 MAF sensor is soooo rediculously expensive???? Atlantic British quoted me $1350.00 as a wholesale price...... Mine was acting up awhile back and I cleaned it out and it has worked fine since but greater minds than mine have informed me it is sure to go bad soon.
2000 Land Rover "Bushranger"
1961 Scout 80 awd
"Every day above ground is a good day"
Al Capone
Bushranger is offline   Reply With Quote
Old 07-02-2009, 09:55 AM   #9 (permalink)
Super Moderator
They miss- quoted you, go to , Land Range Rover Sport LR3 LR2 Discovery Defender Freelander Genuine OEM Accessories Parts
A whole lot less.
Old 07-02-2009, 07:39 PM   #10 (permalink)
Mike -- it's like your standing in front of my truck -- it was doing everyone of those things. I thought I would help things by cleaning it. Now it won't get over a thousand or so RPM....
I'm picking up a MAF tomorrow. Will keep you posted!!
Thanks again
Old 07-03-2009, 07:30 AM   #11 (permalink)
Super Moderator
Have you had anyone test your current MAF to verify it is bad and not an ECU issue?
Old 07-03-2009, 02:08 PM   #12 (permalink)
Replaced MAF today - not much improvement. Dealer says there is a different MAF settings on the 04 ECU for 4.6L than the 02 4.0L.
I just replaced both the ECU and BCU with the correct year and engine size.
Truck is running better than ever.
Still seeing 2 codes after clearing.
P0102
P1884
From other posts, I see that both codes are related to the MAF. I replaced with one from a salvage yard...
Would you recommend a new one, or look further?
Thanks
Old 07-03-2009, 02:32 PM   #13 (permalink)
Super Moderator
102 is a MAF low input circuit, if replaced, the 1884 will go away automatically.
Old 07-13-2009, 09:39 PM   #14 (permalink)
Hi Mike - Thanks for all of the great information. Replaced MAF w new. Disco now runs as new. You're the best!
LR parts, Disco, RRC TheDirtyRover Land Rover Parts and Accessories 4 11-20-2009 03:29 PM
Mass Air Flow Meter Problems GSW Defender 0 12-11-2006 01:22 PM
K&N Filter disco II greekdisco Accessories 35 12-04-2006 09:02 AM
Mass Air Flow Sensor wade Discovery Series I 11 03-07-2006 08:17 PM
Mass Air Flow Sensor for 97 Disco wade Discovery Series I 5 01-31-2006 07:02 PM
