Old 09-19-2008, 12:16 PM   #1 (permalink)
Default disconnecting battery
I plan on disconnecting my battery to remove the radiator. Does anyone
know if i am going to have trouble with the radio or alarm system when i
reconnect. I bought the LR used so i dont have any radio codes.
Thanks, Mike
mtd77246 is offline   Reply With Quote
Old 09-19-2008, 02:15 PM   #2 (permalink)
Pinarello's Avatar
If you dont have that radio code...you will LIKELY need it. Swing into the dealer, explain the problem, and see if they will hook you up with the code. Alternately, you can junk that factory stereo and buy a nice one on the cheap from Crutchfield: LCD TV, Car Audio, Home Theater, Speakers, Plasma TV I hope this helps!
Pinarello is offline   Reply With Quote
Old 09-19-2008, 05:29 PM   #3 (permalink)
You may need the radio code, usually on D2's you won't though. You will need to reprogram the a/c temp system, no big deal.
Old 09-19-2008, 06:59 PM   #4 (permalink)
2002 Discovery II SE
I changed my battery and didnt have to put in the code.
You can call the dealer and give them the VIN. They should be able to provide you with the code. You wont likely need it, but I'd have it in any case. Its good info to know.
2002 Discovery Series II SE. 2" OME Heavy Duty. 265/65R18 BF Goodrich All-Terrain T/A's.
I told my wife if the Land Rover goes, so do I. That shut her up.
Alak is offline   Reply With Quote
Old 09-20-2008, 12:44 AM   #5 (permalink)
good info ....thanks
Door not unlocking with key problem bruinfan90241 Range Rover P38, Mk III and Range Rover Sport 3 03-15-2007 02:12 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Battery discharging OkieRover Range Rover Classic 5 11-02-2005 11:57 AM
Battery Light kdkg Range Rover Classic 6 10-06-2005 06:05 AM
Power failure-2000 RR-please help fdbandit Range Rover P38, Mk III and Range Rover Sport 10 09-28-2005 01:07 PM
