Old 09-19-2005, 08:53 AM   #1 (permalink)
Default discovery 2 vibration during acceleration
hi guys the problem started with a clanking sound that would increase or
decrease with the speed of the truck... then it started to vibrate when i
step on the gas... i dont want to take it to the (stealer) so i'm going to try
fix it my self any suggestions would be apreciated... walt
landroverwalt is offline   Reply With Quote
Old 09-19-2005, 09:29 AM   #2 (permalink)
Super Moderator
02disco2's Avatar
Front drive shaft? I think mine is going south too...
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 09-19-2005, 09:43 AM   #3 (permalink)
Default front drive shaft
ya i think it's the front drive shaft... the dealer wants $ 900.00
rovers north has a proline shaft for $ 399.00 with u-jionts and i'll do
the work... thanx walt
Old 09-19-2005, 11:30 AM   #4 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
You might want to check the rubber coupler on the rear shaft as those often are suspect in any driveline vibrations. Have you checked for any play with the U-joints in the front propshaft? Also when was the last time you greased the prop/driveshafts?
Old 09-19-2005, 11:34 AM   #5 (permalink)
rmuller's Avatar
Tom Woods also sells driveshafts here: http://4xshaft.com .. i think its about $360 for a double cardan with servicable ujoints.
Old 09-19-2005, 11:54 AM   #6 (permalink)
Wheeler
SCSL's Avatar
Exclamation
Ditto what everyone said: front driveshaft.
Replace IMMEDIATELY. Do not wait. If this thing granades it's going to have devistating & costly effects on your undercarriage.
Old 09-19-2005, 12:06 PM   #7 (permalink)
Super Moderator
02disco2's Avatar
Think it's covered under warranty? I love making warranty claims.
Land Rover-less.
Old 09-19-2005, 12:09 PM   #8 (permalink)
rmuller's Avatar
actually it should be, if you still have warranty left.. what i've heard some people do is get the new driveshaft and replace the u-joints on it. I didn't even bother going to try to get it under my extended warranty since i have a suspension lift that probably attributed to it failing.
Old 09-19-2005, 03:23 PM   #9 (permalink)
Default front prop shaft
thanks for the advice i should have the new shaft & u-jionts on friday...
i looked underneath it seems like any easy fix 8 bolts... thanx again
Old 09-22-2005, 08:55 PM   #10 (permalink)
rover has taken over...
hi
I am from KL , Malaysia. I have similar thunking noise coming out from front undecarriage, sometimes even feeling it vibrate while heavy acceleration or deceleration. The short shaft has too much play. Did a warranty claim repair for a new transfer box instead..
a new box is on its way now..
adnanlr is offline   Reply With Quote
Old 09-30-2005, 07:31 PM   #11 (permalink)
Default vibrating prop shaft
o.k i replaced the front prop shaft now my truck drives smooth problem fixed!
Old 10-01-2005, 06:40 AM   #12 (permalink)
Wheeler
SCSL's Avatar
Well done! Just a few days ago I had a chance to see the aftermath of a grenaded front shaft on the undercarriage of a stock DII up on the racks at my buddy's shop. Not good. DII front shafts are scientifically engineered to blow at about 60k,,, ,,,
Old 10-14-2005, 04:51 PM   #13 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
I have to agree with that. cause right @ 63K my U-joint went. driveshaft broke loose. and cracked my transmition case. Luckly I had an extended warantee, otherwise I would to have paid $4100 bucks for a reman-tranny.
RudemanRB is offline   Reply With Quote
Old 10-15-2005, 06:46 PM   #14 (permalink)
guitar588's Avatar
how much would it cost to replace a front shaft
guitar588 is offline   Reply With Quote
Old 10-16-2005, 09:22 AM   #15 (permalink)
Default Drive shaft
You can order an up graded U-joint kit from Bill at Great Basins Rover in Utah for around $100.00.
Mike J.
