Old 10-16-2005, 11:14 AM   #16 (permalink)
Nacho Libre
Hailsharky's Avatar
Originally Posted by Disco Mike
You can order an up graded U-joint kit from Bill at Great Basins Rover in Utah for around $100.00.
Mike J.
What makes it upgraded? Will it last longer the 60K miles?
I dont think I ever had mine replaced and Im at 122K miles.
I Yie Yie...
Hailsharky is offline   Reply With Quote
Old 10-16-2005, 05:19 PM   #17 (permalink)
Default U-Joints
The up grade come in that one some aftermarket u-joints are better then factory but mainly the fact that factory u-joints can't be lubed hence they fail. New upgraded u_joint have grease jerks on the so you can lube then every 10,000 or 15,000 miles.
Mike J.
Old 11-02-2005, 04:14 PM   #18 (permalink)
Default Ouch
Wow I have a 2004 that I just purchased, and it vibrates a little on hard acceleration too. I have to get it in, but with only 25k miles isn't that kinda early for something like a drive shaft problem?
dkoepke is offline   Reply With Quote
Old 11-02-2005, 10:14 PM   #19 (permalink)
jkb2002disco's Avatar
I just purchased an 02 Disco with 31k miles. would the U joint uprgade eliminate future problems or is the stock shaft the problem?
jkb2002disco is offline   Reply With Quote
Old 11-03-2005, 12:59 AM   #20 (permalink)
Choqiees's Avatar
hmm...maybe this is similiar but i'll ask to then
so i run the car for 30 mph then i take off my foot from the pedal immediately, then step on the pedal again immediately about 1/4 of it, then there's this sound like something collides from front under.
someone?
Old 11-03-2005, 01:25 AM   #21 (permalink)
:)----(.Y.)
keptin's Avatar
hmm....maybe its your clutch engaging? I know when I go up some hills my disco gets confused which gear it should be in and sometimes downshifts and upshifts again and makes a rough hault and go bump (or more like jarring ram). Not sure if this is your issue, how load is your noise???
Josh Shapiro
DII
Old 11-03-2005, 08:03 AM   #22 (permalink)
Choqiees's Avatar
well i don't know how to measure the loudness...its just i can hear and feel the jerk too
