Old 09-30-2004, 04:02 AM   #1 (permalink)
Default Discovery 2004 HSE Leaking from Back Door
It seems my Discovery is leaking from the back window when I take it for a car wash. Has anyone else had this problem? I suspect it has something to do with the seal on the back door not being tight enough? It leaks from the top of the door.
2004 - HSE Discovery - 6,000KM
Thank you for your feedback.
agreenway is offline   Reply With Quote
Old 09-30-2004, 10:12 AM   #2 (permalink)
Either the door is not adjusted properly so the seal is not flush or maybe it is a bad seal, either way take it back to the dealer, they will fix it.
Mike J.
Old 09-30-2004, 01:10 PM   #3 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Default Either way....
Let us know what is the outcome, if you decide to dealer it or DIY? Would be interested if you DIY.
