discovery2 with P1590 and P0441 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 07-04-2011, 01:44 PM   #1 (permalink)
Gallery: 2
Default discovery2 with P1590 and P0441
I have a 2001 discovery2 with SAI and it turns on engine check.
The code reader told me P1590 and P0441. The first one is manufacturer
control and the second the evaporative emission system incorrect purge flow
or evap purge valve incorrect fault.
The smog check due date is coming up. Would you please tell me
how I can fix this error? Any suggestion would be greatly appreciated.
ohenry is offline   Reply With Quote
Old 07-05-2011, 07:44 AM   #2 (permalink)
Administrator
The 1590 is because your 3 Amigos are are as for the evap fault, check it for leaks.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 07-06-2011, 07:38 AM   #3 (permalink)
Gallery: 2
thank you, mike.
Old 07-06-2011, 07:39 AM   #4 (permalink)
Administrator
If you need help with the 3 Amigoos, shout.
Need Parts?
Old 07-10-2011, 06:34 AM   #5 (permalink)
Gallery: 2
follow-up...
I replaced the gas cap 3 days ago and found no change. Then I had the purge valve
replaced with the hyundai part, as is recommended in many posts in this web site.
The replacement was pretty easy and took me only 20 minutes. Right after the replacement I fired up the engine and the check engine was still there. Because
I remembered that I saw someone told that he got the code disappear at the third
start-up, I did not give up hope and finally the code is gone at the fourth starting
the next day.
Maybe I replaced the gas cap in vain, but it cost me only 8 bucks and it was worth the
first try.
Thank you for all the posters here for helping me fix my vehicle easily.
Old 07-10-2011, 06:38 AM   #6 (permalink)
Gallery: 2
Thank you, Mike. I have had these three amigos since I bought this car 2 years ago.
The low range isn't working and I wish to go off-road.
Yes. I would like to fix the 3 amigo problem. I need to search the solutions.
Old 07-10-2011, 08:10 AM   #7 (permalink)
Mr. t
MR.T's Avatar
Purchase an abs amigo to read your codes. They're about 200$ but I see them used all the time on here. Pay attention to the classifieds.
Your other option is to have your codes read at a shop that has the appropriate scanner. A simple obd II scanner will NOT work, you must have one to read the abs codes.
once your codes are read, post them here, then the wonderful folks on this forum can help you.
Go ahead and read the two stickys above. No more svs fault and shuttle valve seals. There's a lot of useful info there.
\;/ complete rhino coat interior/MP3 converter(removed 6 disc)/Scan gauge II/2" RTE lift/terrafirma +2 shocks/terrafirma damper/RTE tie rod and drag link/tom woods front drive shaft/97 DI CDL/ K&N filter/RTE wide face front bumper/ SD roof rack and rear ladder/goodyear duratrac's 285/75/R16's/Brembo rear rotors and Will Tillery super secret brand front rotors/ Akebono Euro's all the way around/extended stainless brake lines/saudi spec grille/DI wipers/option "B" amigo free/ And Getting Badder Asser as the days go by\;/
MR.T is offline   Reply With Quote
Old 07-10-2011, 09:38 AM   #8 (permalink)
Administrator
The 441 code won't go away on its own, clear it with a scanner.
Send me your number if you want to walk thru this stuff.
Need Parts?
Old 07-10-2011, 07:17 PM   #9 (permalink)
2003discoII's Avatar
Gallery: 12
any luck getting the evap code fixed?mine just turned on two days ago and it threw the same code.gas cap a not fully tightened so i cleared the code and tightened.day later with no codes it pops back up.looked for any leaks and there is non
2003 disco. exhaust mod,completely stock
2003discoII is offline   Reply With Quote
Old 07-16-2011, 04:26 PM   #10 (permalink)
Gallery: 2
I have P1590 and 3 amigos. There is no engine check on. My code reader also tells
that 3 monitors are N/A and that 5 monitors are ok. What does this mean?
The brake warning light is on because the parking brake switch is broken.
Is this vehicle (2001 discovery2) able to pass the smog test in California?
The due date is coming up. Thank you in advance for any comments.
Old 07-16-2011, 05:32 PM   #11 (permalink)
Administrator
Why don't you send me your number and I'll call and walk you thru thru ABS.
Need Parts?
Old 07-16-2011, 06:02 PM   #12 (permalink)
Gallery: 12
the three amigos are no problem to pass the test and depending on which monitors are ready and which are not is the problem with the california smog it is a pain
Old 07-16-2011, 06:23 PM   #13 (permalink)
Administrator
I bet you have a t/case solenoid causing your low range to not engage.
Need Parts?
Old 07-16-2011, 07:30 PM   #14 (permalink)
Gallery: 2
Thank you, Mike. I sent you an e-mail to give you my phone number.
You are right. The low range cannot be engaged. I wish to go to desert, but I cannot.
Old 07-17-2011, 03:11 PM   #15 (permalink)
Gallery: 2
Help!
I read the codes again on discover2 and it showed codes 2, monitors n/a 3,
monitors ok 5, monitors inc 3.
The codes are 1) engine: P1590
2) transmission: P1884
I was told here that P1590 is due to three amigos and not related to smog check,
but what is P1884 with transmission? Is this ok for passing smog test?
What are monitors inc 3? This is probably monitors incomplete in three cases, right?
Is this ok for passing smog?
P0441 DevilDisco Discovery Series II 4 09-10-2010 04:54 AM
DISCOVERY2 Interior rear seat overhead nets MattZ Discovery Series II 3 06-17-2010 07:20 AM
p0441 gadisco General Land Rover Discussion 2 02-10-2010 07:19 AM
P0441 Touchay Discovery Series II 3 11-12-2009 07:50 AM
P0441 code Chicago Rover66 Discovery Series II 7 10-26-2007 12:17 AM
SEO by vBSEO 3.3.2
