Old 04-25-2006, 12:39 PM   #1 (permalink)
New Land Rover Owner
Default Double-Carbon U-Joints
Can someone tell me how to rebuild these as I am worried about them after reading about the issues in so many posts. Is there a part that can be bought from DAP or Atlantic British? How difficult is the repair/replacement? Any information would be great.
2002DiscoII is offline   Reply With Quote
Old 04-25-2006, 02:49 PM   #2 (permalink)
If you've ever replaced u-joints its the same thing but a little more difficult because you're removing and replacing two u-joints at the same time, plus a center ball joint; lining all three up for assembly without loosing a needle bearing can be an adventure. If you've never replaced u-joints, it might be a bit more of an adventure than you'd want to experience. The best advice I can give you if your going to do it yourself; use the proper technical data and take it step-by-step, mark your parts for reassembly (index), and use a press or vise (not a hammer). If your D/C is fairly new, the only parts you might need are two new u-joints; the center ball may be good enough to reuse.
Whether you do it or a shop does, make sure you get new u-joints with greese fittings (zerks); this will increase the life of your rebuild. Good luck
O.B. is offline   Reply With Quote
Old 04-25-2006, 04:21 PM   #3 (permalink)
Bill at Great Basin Rover has a kit with all the parts you need which includes a better quality u-joint also.
Some people have gone to their local auto parts store and found a u-joint that will work also, I just don't know know if they are any better quality.
Old 04-25-2006, 04:26 PM   #4 (permalink)
Elephantitis penisitis
You can buy the Spicer u-joint to fit your application from a local driveline shop. It will range anywhere from $12 - $30 per u-joint depending on the mark up by the shop.
Old 04-25-2006, 04:56 PM   #5 (permalink)
Ian Matthews
p76rangie's Avatar
just make sure that the unis you get are greasable.
Ian
Old 04-25-2006, 07:10 PM   #6 (permalink)
Roverhound's Avatar
The spicer u -joint is number 5-4x. Try and find that for under $30. I just paid $32 from Standard Parts here in town,Spicer is expensive but worth it. Don't bother with the Napa u-joint. They suck.
It just doesn't matter.
Old 04-28-2006, 03:17 PM   #7 (permalink)
RoverChic's Avatar
Walt~ What parts do I need exactly? My 01 just took a poo...
2006 Range Rover Sport HSE Rimini Red
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 04-28-2006, 03:54 PM   #8 (permalink)
Roverhound's Avatar
The Spicer part number is 5-4x. The Precision number is 344. Avoid the Napa ones if you can. They suck! You should also get the centering kit. Precision 617. Napa has this part also but I don't know who makes it.
I tried to PM you on meany web but it took a poo also!
Have fun on your trip!
Old 04-28-2006, 06:17 PM   #9 (permalink)
If you have never rebuilt a double cardon, you might rethink it and have a shop do it for you. They are hard to do and if it fails while you are driving, you could loose your trannt.
Old 04-28-2006, 06:42 PM   #10 (permalink)
RoverChic's Avatar
Thumbs up
Thanks! Thank you! You are the BEST! I found them at AutoZone or one of those for $$53.97 with tax! I bought three of them. I did not buy the Precision 617, Do I need it?
Mike- A tranny/driveshaft shop is rebuilding the driveshaft for me. I have no idea how to use a press and would hate to see that thing let loose in MOAB!
2001 D2 CDL
Old 04-28-2006, 06:48 PM   #11 (permalink)
Roverhound's Avatar
You may not need it but it's best to replace the centering kit while you have it apart.
Old 05-14-2007, 05:36 PM   #12 (permalink)
California Dreamin'
Rondo's Avatar
Bringing this thread back from the dead. Does anyone know the part number for the centering kit sold at autozone? The knuckle draggers that work there can't find it for me in the computer system.
Rondo is offline   Reply With Quote
Old 05-14-2007, 11:58 PM   #13 (permalink)
center kit info
Rebuild Front & Rear Driveshafts?
ealex is offline   Reply With Quote
Old 05-15-2007, 03:54 AM   #14 (permalink)
California Dreamin'
Rondo's Avatar
I found that but no love from the knuckle draggers with that part #. Can anyone verify that number?
Old 05-15-2007, 06:46 AM   #15 (permalink)
Have you gone to this site, their prices are great.
http://www.rockauto.com/
