Old 01-27-2005, 01:16 PM   #1 (permalink)
Default Draft from rear passenger window
I have a draft coming from my rear passenger window. Cold air is coming in while I am driving. Any thought on how to fix it? Thought about the window trim that needs replacing, if it's that, where do I get the parts aside from the dealer? Any other type of windows sealer work without replacing the parts? Thanks.
Frosty_Power is offline   Reply With Quote
Old 01-27-2005, 01:29 PM   #2 (permalink)
The seal can drop in the window channel it is just a push fit so it can be pulled up by dropping the window and pulling the seal out a little, push the seal up in to the corner and then re locate the seal back in to the channel.
Hope this helps
MG-FRANCE is offline   Reply With Quote
Old 01-28-2005, 02:48 PM   #3 (permalink)
I had the same thing happening on my Disco ll when I bought it.Just as MG-France said, the window felt, (the kind of fuzzy one the glass slides up and down), sometimes gets pulled down by the glass with time.It's just a matter of prying it out of the metal channel a bit, pulling it up a little until it touches the upper window felt, lubricating it a bit with some sort of silicone oil, push it back into the metal channel, and you're done.Be shure to do it for both rear windows.
Carlos
Carlos is offline   Reply With Quote
Old 01-28-2005, 03:24 PM   #4 (permalink)
exact same thing happened to me. I just took it to t he dealership and they pulledthe felt back up to where it was supposed to be, completely fixed the problem.
URdiscovery is offline   Reply With Quote
