Old 07-19-2007, 11:13 AM   #1 (permalink)
Chicago Rover66's Avatar
Default Drivers Front seat
My Drivers Front Seat Will Not Adjust In Any Way...checked And Replaced A 3 Amp Fuse Under The Seat ,still No Movement.
Do You Think The Motor To The Seat Is Bad?
2001 D2 SE7
Chicago Rover66 is offline   Reply With Quote
Old 07-19-2007, 11:54 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
You mean 30 amp, right?
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-20-2007, 05:05 AM   #3 (permalink)
it was a 3 amp fuse. there is a yellow square fuse,40 amp,and two 3amp fuses right under the front seat. it looks like they are connected to the seat motor
2001 D2 SE7
Old 07-20-2007, 05:24 AM   #4 (permalink)
4x4 Adventure Gear
John C's Avatar
Ahhh, I remember the RR had a 30amp green fuse that would control the forward/backward and reclining movement. Must be different on the DII.
Are there any fuses for the seats on the large fuse panel?
John C
Old 07-20-2007, 07:29 AM   #5 (permalink)
not that i could find, i checked the large panel first, all seem to be clear of any blown fuses. i wonder if its the square yellow fuse,i have no way of checking that. i did switch that square fuse with the one on the passanger side. no power to the seats.Hmmmm lol that might be my problem.(DUH!!)
2001 D2 SE7
Old 07-20-2007, 08:23 AM   #6 (permalink)
4x4 Adventure Gear
John C's Avatar
I believe you can interchange the yellow relays, you might even find them at an auto parts store.
You sure it's not the switch? personally I don't think the seat motor has gone bad.
John C
Old 07-20-2007, 08:35 AM   #7 (permalink)
i'll try to find the relay.....i could be the switch, how can i test for the switch?
2001 D2 SE7
