Old 11-14-2006, 02:31 PM   #1 (permalink)
u2ra_winner's Avatar
Default Drivers Window fell into door
When I last tried to put the window down it fell into the door.
Now the motor runs but nothing happens.
Is this common?
If so should I attempt to fix or just take it to the dealer.
THNX
Michael
2003 Disco HSE7
http://www.cardomain.com/ride/2407379
u2ra_winner is offline   Reply With Quote
Old 11-14-2006, 02:45 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 3
Take it to the dealer.
I had them replace both my window regulators.
The passenger was dropping a bit and I told them the driver's side did it too occassionally.
SO they replaced both.
Old 11-14-2006, 03:07 PM   #3 (permalink)
Sounds like you broke a window regulator and yes it does happen more then it should.
I agree with the last post, get it into the dealer for replacement under warranty.
If you are not under warranty you can buy a new window regulator on line cheaply.
Old 11-14-2006, 03:48 PM   #4 (permalink)
DATW's Avatar
It is a common break, way more common than on any other vehicle I have dealt with. I replaced my D1 twice and now my DII passenger has failed. If you are not under warranty replace it yourself if you feel comfortable doing repairs. The hardest part is trying to figure out how to angle to regulator to get it in and out of the hole in the door. There is a write up on Discoweb about how to do it. The regulator is available from Atlantic British or Rovers North, about 100.00-125.00 for the part. When you get it out you will see what failed, a plastic roller than probably cost .50. I have heard of people repairing with a screen door roller but I have not looked into it.
Hope that helps,
Jeff
'03 Drive Around The World DII #5
DATW is offline   Reply With Quote
