Old 02-26-2007, 01:17 PM   #1 (permalink)
Steph's Avatar
Default Driveshaft rebuild
Gents, I just called my local big trucks susp. and driveshaft place and they said they couldn't do the u-joint replacement and driveshaft service job, due to the fact that they do not have any listings for the Land Rover Discovery.
I asked him if it would help if I'd get back to them with the part number of the u-joints. They said most definitely.
So.......Anybody has the part# for the greasable spicer u-joints ?????
Thank you,
Steph
Steph is offline   Reply With Quote
Old 02-26-2007, 01:20 PM   #2 (permalink)
Elemental's Avatar
Oh Gosh! I had the same thing, untill I brought it in and he matched them up on sight. I dont know the numbers, but they are just afraid of something that isn't a Chev/Ford/Dodge truck.
Old 02-26-2007, 01:29 PM   #3 (permalink)
landrovergeek's Avatar
Thank you,
Steph
on my 99 d2, i rebuilt mine myself. i used "precision" greasable u joints.
front shaft
- 3 u joints (precision 344)
- 1 ball centering kit for the double cardon (precision 617)
rear shaft
- 1 u joint (precision 344)
thanks and good luck
landrovergeek
99 D2 kinversand
Miami Valley Land Rover Society
www.mvlrs.com
landrovergeek is offline   Reply With Quote
Old 02-26-2007, 01:55 PM   #4 (permalink)
front shaft
rear shaft
That is exactly the combination used on my 99 D2, partrs are easy to find and if you don't want to do it yourself, nearly any tranny shop can rebuild a double cardon. If need be, take the front shaft off yourself and take it to the shop, save some money, in the mean time, engage your CDL and drive around on the rear until the shop is done with your front drive shaft.
Old 02-26-2007, 03:36 PM   #5 (permalink)
Steph's Avatar
I'll do that (take the shaft off and bring it in) It is the front one that needs to be serviced urgently, isn't it???
I won't drive it though, I'll use the Jeep. I've been kind of neglecting it since I got the disco 2 months ago.
P.S What is the difference in cost between doing it myself and having it done ???
I mean how much should I expect to pay in parts ???? and how much should I expect to pay in labour should I decide to have it done ???
Thanks,
Steph.
Old 02-26-2007, 05:55 PM   #6 (permalink)
You will be looking at about $40 apiece for the u-joints and since it is out, do all 3 and be safe. Labor at a shop would be around $100 to $120 for the 3 joints.
Old 02-26-2007, 06:02 PM   #7 (permalink)
Roverhound's Avatar
Go to www.rockauto.com to save significantly on the u-joints. Search by part number.
Or you can go to Auto Zone and get PDQ1-0005 u-joints. These are Neapco u-joints with the grease zerk on the end cap and beefier to boot. They will only run you $15 a piece.
If you go to discoweb and do a search on the this oft repeated topic you will find the Neapco part number for the centering kit.
It just doesn't matter.
Old 02-27-2007, 05:33 AM   #8 (permalink)
Offroader
DFW Rusty's Avatar
HEHE! I bought all the parts for about $90 roughly and I got a guy that runs a tranny shop that is going to do all the work(take the shaft off, and rebuild it) for $40!
'07 Jeep JK unlimited, 3" full traction lift, 35" ProComps, TracLok rear, traction control front
http://s66.photobucket.com/albums/h2...offroad087.jpg
http://s66.photobucket.com/albums/h2...garun08032.jpg
DFW Rusty is offline   Reply With Quote
Old 02-27-2007, 07:21 AM   #9 (permalink)
Spicer part number is 5-4x. For what it's worth, some say that Spicer no longer makes them, other's say they are now made for Spicer but not by Spicer and others say that there is stock out there, just need to find it. Try asking for a 1993 Volvo 240. That's what I asked the guy at Advance Auto and he got me the PDQ/Neapco 1-0005 u-joints, a popular replacement for stock.
see: http://www.lrfaq.org/RR/RR.u-joint_replacement.html
Kevin
2000 Discovery 2
CDL Lever
245/75 R16 Goodyear MT/R
hevkev is offline   Reply With Quote
Old 02-27-2007, 10:37 AM   #10 (permalink)
Roverhound's Avatar
And it's virtually identicle to the Spicer unit. I have both in mine so I know this as a fact.
Try finding the Spicer, it ain't out there.
Old 02-28-2007, 08:07 PM   #11 (permalink)
imag's Avatar
Default at RockAuto.com
PRECISION Part #617 @ $24.79
PRECISION Part #344 @ $17.16
Have just bought 3x 344's and 1x 617 there.
2001 Discovery SE7
imag is offline   Reply With Quote
