![]() Join Date: May 2005
can i wire hella lights on a new Rovertym bumper with the existing fog light wiring?
Moderator of the East Coast and Discovery 2 sections! 2001 Disco II SE w/CDL ~Equipe 4x4 Winch Bumper ~Custom steel rear bumper ~Equipe 4x4 steering skid and radiator skid ~RTE rocksliders ~QT services front and rear diff guards ~2" RTE lift ~265/75 r16 Federal Couragia MTs ~Superwinch X9 ~Safety Devices Roof Rack |
Super Moderator
No. The fog light wiring will not be able to cope with the current required to light your driving lights. If you want to use the fog light switch to turn both on, you will need to upgrade the wiring gauge and relay.
i will not be running both...just the hellas. i wil not have the fog light on my new bumper
Super Moderator
You'll be JUST fine as long as they use the same wattage bulbs. It doesn't matter one bit if they are driving or fog lamps, that is the lens, not the bulb. If you stick with the 55W bulb that is in most driving lights, you'll be 100% okay with the factory wiring since your factory fogs have the same bulb in them to begin with.
Land Rover-less. -------------------------------- 2006 Infiniti QX56 - Loaded 2002 Discovery II SE - SOLD! 1999 Audi A6 Avant Quattro Tiptronic - Slammed on RS4 18's 1996 Mariah Talari w/350 Mercruiser and Ron Hill Marine Go-fast parts.(Presently in Dry Storage) |
well...i don't have any yet, but they are in the near future!
:)----(.Y.)
![]() Join Date: Oct 2005
I agree w/ 02disco, but you have to keep in mind:
The fogs are such that they only function on low beam, so its not even worth using them unless you are replacing them with other fog lights; (ie, Hella Micro DE's). You also have to have the lights turned on and the engine running; you might want to be able to run the lights independently of them. I suggest you buy a cruise control switch from EE ($27) or find one from a junkyard and use it to wire up some more powerfull 100w-130w hella rallye 4k's. Then when you press in they turn on, and when you press again they turn off.....its all nice and clean on your dash (because there is room for an extra cruise control button) and you can run it independenty of the engine, lights, etc.
Josh Shapiro DII |
