Dual Battery Tray - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-27-2013, 02:31 PM   #1 (permalink)
Daedrix's Avatar
Default Dual Battery Tray
Made myself a dual battery tray. Its not 100% yet though.
Going to replace the hardware that way no studs poke at the battery and maybe paint
~Patrick
03 DII, 2" lift, ARD Brush Guard with Warn W8000 Winch + 2 PIA lights, and Safari Rack with 4 PIA + 1 utility light. Tom Woods front drive shaft. Michelin 4X4 O/R - 7.5 16C 116/114N Tires. My disco web album, have a look here.
Daedrix is online now   Reply With Quote
Old 01-27-2013, 06:40 PM   #2 (permalink)
Nice job! Looks good! Im sure though that this thread will turn into a thread about how shitty optimas are, but let me be the first to say it looks great.
lanceputnam is online now   Reply With Quote
Old 01-27-2013, 06:59 PM   #3 (permalink)
Daedrix's Avatar
Thanks, I'm sure it will at some point I plan on getting another one soon and running them in parallel for now until i get an isolator hooked up, but for right now im going to get better hardware and a strap which is easy.
~Patrick
Old 01-27-2013, 07:04 PM   #4 (permalink)
What are using the extra juice for?
CFDRover is offline   Reply With Quote
Old 01-27-2013, 07:20 PM   #5 (permalink)
Daedrix's Avatar
On a side note, can anyone provide a wiring diagram for the batteries so that one runs the car and the other runs the accessories winch,fridge etc whilst charging both at the same time?
Thanks in advance.
~Patrick
Old 01-28-2013, 08:11 AM   #6 (permalink)
Administrator
Try running parelle for a while, I have for the last 11 years and with 2 Yellow Tops and they have averaged around 7 years of life prior to failing and my winch pulls like a mule.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 01-28-2013, 01:50 PM   #7 (permalink)
Daedrix's Avatar
Winch mainly, lights, and sub woofer amp (1800 rms 2400 peak)
Ill try that rout mike.
~Patrick
Old 01-28-2013, 03:34 PM   #8 (permalink)
Administrator
Two thoughts, a winch will pull harder on dual batteries and if you drill a few large 1" holes in the battery box, it will allow the batteries to run cooler.
Need Parts?
Old 01-28-2013, 03:58 PM   #9 (permalink)
Daedrix's Avatar
In the wall that separate them or the floor?
~Patrick
Old 01-28-2013, 04:07 PM   #10 (permalink)
Nice, I may have to try that too.
Sent from AutoGuide.com App
Old 01-28-2013, 05:58 PM   #11 (permalink)
Administrator
The floor. The cooler the battery stays the more out put it will make.
Need Parts?
Old 01-30-2013, 03:00 PM   #12 (permalink)
Scrubo's Avatar
Smart idea! I might try that myself.
When in doubt, hit the gas
Scrubo is offline   Reply With Quote
Old 02-02-2013, 10:55 PM   #13 (permalink)
Rover_Hokie's Avatar
Gallery: 7
Nice work, looks good! Make sure to put some hold downs on those batteries. Are those size 34 batteries?
Tony
Black '01 D2 140K AMSOIL Synthetics
GO HOKIES!!
Rover_Hokie is offline   Reply With Quote
Old 02-03-2013, 05:57 AM   #14 (permalink)
Administrator
If that is the same Yellow Top as mine, yes, they are 34's.
Need Parts?
Old 02-03-2013, 02:22 PM   #15 (permalink)
Daedrix's Avatar
I use a simple pull strap to hold them down and they are 34's just like Mike's.
~Patrick
dual battery White Widow Range Rover Classic 0 01-08-2012 08:03 AM
Dual Battery Setup mcleoddude Discovery Series I 6 12-03-2010 11:00 AM
95 LWB - dual battery set up - where to install the 2nd battery? ducsurfer Range Rover Classic 3 01-06-2010 05:31 AM
Dual battery project rover1st Defender 5 11-28-2006 08:03 AM
Battery Dual DiscoRick Discovery Series II 2 01-28-2006 07:20 PM
SEO by vBSEO 3.3.2
