Old 07-25-2007, 01:46 PM   #1 (permalink)
Default ECU help
I have a 2000 DII with 93000 miles, its been throwing a o2 sensor code, well the o2 sensor is fine and the harness is fine. My Mechanic says its a bad ECU its stuck on thinking its .44v My mechanic has done everything he knows how to, to try and fix the problem. I thought i read somewhere about an ECU recall of some sort but cannot find any information. HELP me
Scott
He ran a T4 test book through the ECU for what its worth
scottagnew101 is offline   Reply With Quote
Old 07-25-2007, 06:09 PM   #2 (permalink)
picked up the car tonight. Its actually reading 44.7v which is the default way of saying its a bad o2 sensor so that the driving conditions are normal. Looks like im in the market for a new ECU
Scott
Old 07-25-2007, 06:49 PM   #3 (permalink)
Roverhound's Avatar
How do you know the o2 sensor is good? How was it tested?
It just doesn't matter.
Old 07-27-2007, 08:59 AM   #4 (permalink)
He tested the sensor, both harness, and the hareness that goes ALL the way back to the ECU. He has spent ALL day with this thing. He told me about a million things that he has done and he said it all points back to the ECU. he unplugged the o2 sensor and it still says its at 44.7v
He used the T4 test book to conduct most of the test.
Old 07-27-2007, 03:50 PM   #5 (permalink)
tell me the codes first and then we can decide whats bad and whats not.
Old 07-30-2007, 09:27 AM   #6 (permalink)
Its just a simple "no connectivity code"
Error code P0160 last time i checked it (the light has not gone off so it should not have changed)
Rovin, if you have any advice with this please let me konw,
Thanks
For what its worth, i have unplugged all of the o2 sensors and double checked the connection (to make sure its in ALL the way) and they all clicked in. however, the one that is bad (bank 2 sensor 2) is missing the white center cap on the rovers harness. I have been told its nothing major.
Old 07-30-2007, 07:06 PM   #7 (permalink)
run a new wire from the ecu to the oxygen sensor. make sure to use gold plated ends for the oxygen sensor. the dealer has them.
if that doesnt work then put an ecu in it.
Old 07-31-2007, 06:52 PM   #8 (permalink)
hey roving.... we just received truck #20 of 40 of the 20th anniversary
at 150k, i did the pdi and that frigging kebol clock what a pita to set.
the paint job on all handles and mirrors is a horrendous with overspray
and lack of clear coat.
the leather with uncustured seams. the wheels were nice thou.....
this thing was to be shipped to its owner somewere on the mid west.....
It was not worth the extra 70k on the tag on my opinion.
carlosz is offline   Reply With Quote
Old 08-04-2007, 06:41 AM   #9 (permalink)
those vehicles went to centers with the highest sales. Not the ones that were actually around.
I know a guy from one dealer that was around for twenty years and missed it because of sales. really pissed them off too. They werent grandfathered in due to actually being there for twenty years.
Old 08-06-2007, 03:42 PM   #10 (permalink)
I was not aware of such, I really do not mingle with the sales dept., and the only tyme I hang at the front showroom is to pick up keys, I avoid being there too long (showroom) because that is the main hang out of the general manager, you know what I mean.
Old 08-07-2007, 06:15 PM   #11 (permalink)
For what its worth, problem is...for the most part... solved. Oil had leaked onto the top of the pass front o2 and threw it out of wack, which in turn threw the rear otta wack. It was stuck that way for so long that the ECU was stuck thinking that. Well 2 o2 sensor, an ECU flash, and a hard reset later ($550.00 good as new)
