Old 08-23-2005, 08:42 AM   #1 (permalink)
Question Electric seats problem
Hi All:
I have a 2000 Discovery with electric front seat adjustment. The driver's seat plays up intermittently - currently only the front squab portion of the seat moves up and down, and the lumbar support pump works. Nothing else works, the switches move, but the seat motors refuse to obey... Any ideas?
regards
Mistervan
Mistervan is offline   Reply With Quote
Old 08-23-2005, 09:30 AM   #2 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
You might need to open the switch and clean it. Most likely that switch has gotten more use than the passenger seat so contacts might be dirty. I would open it up and clean it... by that I don't mean open the switch just take it out and clean the contacts for the plug. You might need to open the unit itself but as I have not done this I'm not sure if you can without ripping it apart You can use compressed air to try and blast the dirt off before you take it totally apart, but I'm not sure if that will do the trick.
I would also check all the plugs to make sure nothing it loose... plugs can fall off.
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 08-23-2005, 10:12 AM   #3 (permalink)
Super Moderator
02disco2's Avatar
When is the last time you lubed the seat rails?
Maybe it is binding up and the motor doesn't have enough juice to move it??
The only issue I had was I blew the 40amp fuse.. the problem was located and the main power wire had chaffed and grounded out. Thank God for warranty!
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 09-29-2005, 04:23 AM   #4 (permalink)
Hi All:
Any more thoughts / ideas on this one? I recently swopped the drivers' and passenger switches, and the problem STAYED with the drivers seat - so obviously NOT the switch.... What now - do not want to take it to the stealer. Mistervan
Old 09-29-2005, 04:50 AM   #5 (permalink)
Super Moderator
Disco's Avatar
Some Discovery's have had problems with the electric seats, where the seat, when powered forward to its full travel with the front of the seat in its lowest position, sticks/hesitates. Does it hesitate? If so, power the seat to the rearmost position and check the seat fixing bolts for evidence of fouling (if the seat does not move, perhaps its stuck on the bolt head). Apparently, there are two different seat fixing bolts. The ones for the 3 door model are longer and have a higher head, than those for the 5 door model. The factory could have fitted the wrong ones.
Old 09-29-2005, 05:51 AM   #6 (permalink)
Roaming_Pig's Avatar
Originally Posted by Mistervan
Hi All:
Have you checked the fuses yet?
04 D2...Sequel to the Pig
Roaming_Pig is offline   Reply With Quote
Old 09-29-2005, 07:51 AM   #7 (permalink)
Absolutely. Checked the fuses several times.
Sometimes the motors make a noise, but no movement, other times no noise, and no movement.....!
Thanks. Mistervan
