Old 03-30-2008, 02:41 PM   #16 (permalink)
ultrrunr's Avatar
Rovin4life recommended I use it on the rocker cover gaskets as well as around the water ports between the intake and heads. I cleaned all the surfaces EXTREMELY well before reassembly but I figured the extra sealant couldn't hurt. I hadn't used the aviation sealant before but it seemed to work pretty effectively. It comes in a little white bottle from NAPA with a brush applicator. It tells you to apply to both surfaces, allow to dry for a minute or two then reassembly. It becomes a bit tacky and made assembly a snap. The aviation sealant is very resistant to aviation fuels and oil based fluids as well. I hope it works. I am counting on having a clean engine.
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
« Vin | Radiator Leak »
Snow Emergency sanger Range Rover P38, Mk III and Range Rover Sport 15 03-06-2008 02:20 PM
Bit of an emergency... DiscoTex Discovery Series I 7 10-05-2006 11:28 AM
Coolant hoses to plenum? Kevin88RRC Range Rover Classic 4 07-14-2006 12:38 PM
'93 Range Rover emergency brake stuck trellis8 Range Rover Classic 6 07-03-2006 09:57 AM
Plenum??? Jonesy Range Rover Classic 9 01-10-2005 07:29 AM
