Old 03-29-2008, 12:26 PM   #1 (permalink)
2000 Disco II
Unhappy EMERGENCY!!! Plenum Chamber
2000 Disco II
115K of pure fury
Alright here's the skinny. Need to replace spark plug wires, plugs and valve cover gaskets...I have replacement parts for all (magnecors and big thanks to Atlantic British). How the heck do I take off the plenum chamber???
I have the top four bolts off and i'm trying to take off other stuff but I can tell that i'm definitely gonna take stuff off that i don't need to.
My garage is currently occupied by my disco and i'm getting my A kicked right now
PLEASE HELP!!!
aben112358@yahoo.com
or PM me
DiscoBenny is offline   Reply With Quote
Old 03-29-2008, 01:11 PM   #2 (permalink)
Dou you need to replace the v/c gaskets, vally pan or intake manifold? If not don't, you can replace the wires without pulling the intake off.
Old 03-29-2008, 01:14 PM   #3 (permalink)
2000 Disco II
yeah I need to replace the v/c gaskets on both sides...i have wicked oil leaks from both
There is just a lot of stuff that I don't know about coming off an what not for this
Old 03-29-2008, 02:39 PM   #4 (permalink)
Have you tried to tightem up the 2 out bolts on each v/c gasket, they usually get loose and leak.
Just trying to keep you from doing a bunch of work you are not probably ready to handle.
Did you buy a new $60 plus gasket thst goes between the upper and lower manifold, if not get one before you start.
Old 03-29-2008, 04:04 PM   #5 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
I haven't ripped into mine yet but looking at the plenum gasket it looks like it has more than 4 bolts?
I'm hoping I can flip the plenum to the right side wheel well after I get it unbolted?
I'm going to do the same thing to my 01 D2 here shortly.
Got my Magnecors from Apex around $92 shipped I believe.
Plenum gasket from D.A.P. for $12.66.
Valve Covers gaskets from D.A.P. $6.50 each.
Just waiting to pick up a new belt and I'm going to rip into her.
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 03-29-2008, 04:32 PM   #6 (permalink)
2000 Disco II
yep. Tightened one a while ago but it was still going then the other started so I figured i'd wait til i got the spark plug wires in to change everything that is related to me taking off that plenum chamber.
Already have gaskets for the v/c's and intake manifold(err6621). I am just wondering if there is some jedi tips on getting this plenum chamber off rather than just taking off the 69 nuts and bolts that i see and messing things up. how long is this supposed to take by chance...i have a poker night event @ 730 that i was planning to go to but we'll see...
Old 03-29-2008, 05:20 PM   #7 (permalink)
Do you have secondary air, an emisson control device?
Old 03-29-2008, 05:43 PM   #8 (permalink)
2000 Disco II
negative. Probably should have cleared that up originally. Sorry its my first post/problem
I can tell that i have to roll to autozone to get the screw type clamps for the hoses and what not. But seriously, i thought this would be an easier job than when i used to work on F-15s
Old 03-29-2008, 06:25 PM   #9 (permalink)
F-15's? KYS hahahahahah
bennysdiscosucks is offline   Reply With Quote
Old 03-29-2008, 06:27 PM   #10 (permalink)
Didn't answer my question.
If you want help you need to reply.
Old 03-29-2008, 06:34 PM   #11 (permalink)
2000 Disco II
Disco Mike: You asked if I had secondary air, an emission control device and i replied with "negative" since i do not have secondary air.
i got some hoses off and i'm definitely gonna start back gain tomorrow
Old 03-29-2008, 06:58 PM   #12 (permalink)
Sorry, I slid right past your reply, been a long day.
Old 03-29-2008, 07:26 PM   #13 (permalink)
2000 Disco II
dude there's no worries bro!!!
Old 03-29-2008, 08:03 PM   #14 (permalink)
ultrrunr's Avatar
DiscoBenny - I just finished up my head gasket this week so I had all that junk apart on my 00 SE7. I'll shoot you a PM. I'm no LR genius but I will be glad to share with you what I gathered in my job.
Micah
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
Old 03-30-2008, 12:00 PM   #15 (permalink)
2000 Disco II
Sweet deal thanks Disco Mike.
Ultrrunr, you're not kidding about the wires...knuckles are officially BUSTED .
Whats up with this aviation sealant you're talking about? You use it WITH the new gaskets as a combo deal? Or just stand alone on its own?
Happy Sunday All
« Vin | Radiator Leak »
Snow Emergency sanger Range Rover P38, Mk III and Range Rover Sport 15 03-06-2008 02:20 PM
Bit of an emergency... DiscoTex Discovery Series I 7 10-05-2006 11:28 AM
Coolant hoses to plenum? Kevin88RRC Range Rover Classic 4 07-14-2006 12:38 PM
'93 Range Rover emergency brake stuck trellis8 Range Rover Classic 6 07-03-2006 09:57 AM
Plenum??? Jonesy Range Rover Classic 9 01-10-2005 07:29 AM
