Old 03-30-2008, 07:49 PM   #1 (permalink)
fiach's Avatar
Default engaging CDL
I have myself an '03 Discovery 2 and I got stuck a couple weeks back and I think its cause my diff lock wasn't engaged. Do I even have CDL? How can i tell? What do i look for? (pictures) and how do I engage it?
fiach is offline   Reply With Quote
Old 03-30-2008, 08:04 PM   #2 (permalink)
'00 DII Member
auwesman's Avatar
'03 does not have CDL or the nipple to engage CDL
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 03-30-2008, 08:08 PM   #3 (permalink)
fiach's Avatar
BOOOO
so pretty much it's half as capable?
Old 03-31-2008, 07:07 AM   #4 (permalink)
YUP!!
But the good news is that the 03 has an updated ETC and is more capable then the earlier D2's, once you learn how to drive with it. You do have the option of installing a Used t/case with CDL.
Old 03-31-2008, 09:19 AM   #5 (permalink)
Do all 2001 Disco's have the CDL?
Neo1975 is offline   Reply With Quote
Old 03-31-2008, 09:52 AM   #6 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
No just the very early model year ones.
LIKE MINE!!!!
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 03-31-2008, 10:09 AM   #7 (permalink)
2004 Discovery II driver
1 year later you woulda been fine haha
stolenheron is online now   Reply With Quote
Old 03-31-2008, 11:14 AM   #8 (permalink)
01's that were built before jan. 01 will have them for sure.
Look on your drivers door for your trucks production date.
Old 03-31-2008, 12:01 PM   #9 (permalink)
Bamafan485's Avatar
Gallery: 9
Do all 99's have it? If so, how do I engage it without building that lever through my console?
Will Akins
'99 Discovery Series II
'02 BMW X5 girlfriend's
Bamafan485 is offline   Reply With Quote
Old 03-31-2008, 12:43 PM   #10 (permalink)
Yes, your 99 has it. It can be engage by crawling under the truck with a wrench or installing the shift linkage from a D1 or an 04.
Old 03-31-2008, 02:33 PM   #11 (permalink)
I will check the date.
Old 03-31-2008, 08:12 PM   #12 (permalink)
Date reads 01/01. Hope that means it has the cdl. Haven't got under there and looked yet.
Old 04-01-2008, 06:45 AM   #13 (permalink)
Neo,
You are on the line and now you will need to crawl under and see if you cna feel the shift nipple to know for sure.
Look at the attached picture, notice the round plate that is attached to the top of the t/case with 3 bolts. If yours has that center nipple in the middle of that round plate you are in luck.
Old 04-01-2008, 07:30 AM   #14 (permalink)
Thanks for the pic Mike. I will definitely check it out. It wasn't bought for a offroad vehicle, but you know how that goes.
Old 04-01-2008, 12:18 PM   #15 (permalink)
Mr.Petersen's Avatar
Gallery: 2
Noe1975, why buy one if that's not what it is used for?
Mr.Petersen is offline   Reply With Quote
Manually engaging CDL on 2000 disco? wr0x2 Discovery Series II 9 12-02-2008 01:45 PM
Not engaging gears! troverman Discovery Series II 4 12-14-2005 10:06 AM
Reverse disengages when engine off? Jayce Series Land Rovers 7 09-02-2005 03:49 AM
Diff lock engaging Marcus General Land Rover Discussion 5 02-17-2005 02:38 PM
